OT: Electronics question
Craig in Silverdale
>I need some help. I have a mountain cabin with a solar cell for power. I just found an LED lite at Harbor Junk. It uses 3 1.5v AAA batteries. How would I go about wiring it to my 12v system? I know it will need some resistors in line, but I need to know what formulas I use to determine what size. Is it really that simple? Can anyone direct me to a web site that would explain this? Thanks to all who respond.
Re: OT: Electronics question
Re: OT: Electronics question *LINK*
John McGaw
>Resistors are a bad idea. Resistors can be used in series with a single LED or a string of LEDs but is incredibly wasteful of energy -- far more of what you feed in from your scarce solar power is turned into heat. The light you are describing almost certainly has active current regulation circuitry and this too could be thrown off by attaching a resistor. Far better IMHO would be to invest in an LED "puck" light which is designed and built to run directly off of 12V. There are quite a few puck lights available in the 1W to 3W+ range and, although they are not cheap, they will be more efficient and are likely to last much longer.
An Example of an LED Puck Light
Kneale Brownson Dreaming of the Snow in N. MI
>Or get one of the Sears rechargeable Led worklights that have a 12 volt charger option:
They had them on sale recently for $15. Now they're back to twice that.
Rechargeable 110/12 volt LED light
Chuck W
>Or you could make a simple voltage divider using some resistors.
Dan Donaldson
>Resistor dividers work, but as mentioned, they waste a lot of power. With a photocell power supply, I would not want to waste any more power than I had to. Either an led lamp with supplies built in, or a switching power supply would be a much better use for this application.
Larry Clinton At Frankfort (Central)., Indiana
>At this site they have 12V battery chargers for the AAA thru D-cell size ni-cad batteries ($18). this would allow you to charge batteries and use them even when there is no sun. They also have a solar charger for AAA cells for $9 - haven't bought any thing there -just googled up the site. http://www.advancedenergyonline.com/catalog/power%20storage/solar%20battery%20chargers.htm
How about a simple regulator?
John in New Mexico
>Recently made one at work for our wind meter, though it required higher current than an LED lamp. Good link for building a really simple one with a wide range of specifications:
http://www.reuk.co.uk/Zener-Diode-Voltage-Regulator.htm
In the mean time if the OP wants to try the resistors its pretty simple and inexpensive to do so. Just need the current draw of the little lamp and its resistance. Then you just use Ohms law to calculate how much resistance to add, (12v - 4.5v) = total r * current. Then you need to calculate the power capacity of the resistor you add. P = current * voltage. Round up the power to the next biggest available increment (1/4 watt, 1/2 watt, etc) for the resistor.
Though this is a pretty wasteful way of dropping the voltage, I wouldn't imagine that the lamp draws much current, so the heat (waste) from the resistor should be negligable. Quick way to get started anyhow.
