Re: Small Display Case Joinery
Rob Stokes in North Vancouver
>I'd run full length splines (look closely at the lower left corner of the left box in the picture linked below). These were done in 3/8" stock without a problem, but your box will be taller.
I'd mill the stock to 3/8", leave it wide, cut the mitres, cut the spline grooves (using both sides of the wide stock) and then cut the pieces off you want to use for box corners. Leave the pieces long and cut a groove in the fresh cut edge to accommodate the glass. I's use a router table and small (1/8"??) straight bit for this as it would be a little hairy running this stock over a table saw. Either way, use feather boards and push sticks.
When you cut spline stock, plane your stock to thickness (you'll want a fairly loose fit - looser than you think as you'll need room for alignment and glue) and x-cut pieces off so the grain is perpendicular to the mitre slot. Use multiple pieces of spline stock in the grooves,. Leave 1/4" between each piece of spline stock for expansion contraction.
putting a dab of glue at the center of each of the spline pieces but not gluing the ends, glue the corner pieces together to form the corner posts and clamp (masking tape works well). Cut to length after the glue dries and carry on with the rest of the box.
If you *really* want to get tricky, this same corner post "stock" that you made up could be used in a three-way-miter to also form the bottom and top of the box, using 1/8" plywood instead of glass for the panels.
good luck!
Rob
