>When I went to empty the dishwasher today, there was about an inch and a half of water left in the bottom that didn't drain out. I tried running it through just a rinse cycle to see if that drain the water out. It didn't, still left about an inch and a half in the bottom.
>Check the float. If that's OK, I usually just start disassembling the drain area. Something usually becomes clear then. Broken glass or a piece of plastic stuck in there somewhere.
>I had the same problem every few months with an old dishwasher. I never fully figured out the problem since we ended up replacing it (not for that reason).
The quick fix for me to was to start a cycle and then hit reset after 20-30 seconds, telling the machine to empty all the water out. After 2 or 3 rounds of that, the machine would usually be empty....and would run normally for several weeks.
>I had that once. I never found out but it must have been a blockage of somekind. If you have easy acess to the drain line use a compressor and give it a puff of air. Worked for me and has not returned.
>What kind of D/W you have?? First check the air gap (if you have one) It is installed on the counter or sink. Sometimes the air gap gets plugged. Just lift the cap and check for blockage.
>You may want to check the check valve which keeps discharge water from flowing back into the unit: it is either located near the pump discharge, or some units (I believe) have it in the discharge line.
