Hot Dawg Garage Heater
howard
>I've received several recommendations for this to heat my new 2 car garage shop. Could you help me with a few questions, hopefully from owners of the unit. The garage is 24' square, 10' ceilings, r-19 in the walls and r-30 in the ceiling. Modine says I need a 30,000BTU unit. So you think the split combustion unit is needed for a wood shop(air intake pipes from outside)? Also, I have done lots of pipe work and electrical, but not venting. I wanted to use the option of venting through the wall, any issues with this, is installation striaghtforward. I appreciate your help.
thanks
Re: Hot Dawg Garage Heater
Craig Frasa
>Howard,
I had my Hot Dawg installed but watching the installers I realized this is something you could do yourself if you have experience working with gas lines.
Mine vents through the wall and for 2 winters it has worked great.
Good Luck,
Craig in Clarkston
What model # do you have
howard
Pat Riley
>I didn't go with the HotDawg. Got the Mr. Heater from Northern Tool. It was the only one available at the time, and was actually a bit cheaper than the HotDawg.
From the sounds of your shop, with all the insulation you have the 30,000 btu unit should be fine.
Mine is vented through the wall, and uses combustion air from inside the shop. My shop isn't exactly ultra sealed, so drawing combustion air from inside the shop is not a big deal. If your space is tight (and it sounds like it is) I would probably go with drawing the air from the outside.
As far as venting goes, it was simple. Northern had a vent kit that had all the double walled pipe, caps and flanges to properly penetrate the wall. It ended up being less expensive than buying the parts separately.
There can be a bit of a condensation issue with exhausting horizontally. You can either provide a drain tube (kind of a pain)or slope the piping (works because of the forced air exhaust). You only need about 1/8" per foot of slope and the condensation will just drip out if you ever get any (it turns out I never do)
If you want any other info or pictures etc, drop me an email.
Pat
Al Stokka - Cambridge, Iowa
>Howard,
I have the 45,000 btu model, vented through a wall. Double garage, insulated overhead door, R30 ceiling with drywall, drywalled walls but (I think) no insulation in the walls, two south-facing windows, one half of one wall attached to the house.
I did all the installation myself except...needed help attaching the heater to the ceiling, and had the propane dude install a pressure regulator and give his approval of my piping - all was fine.
I bought the through-the-wall venting kit (about $35 if I remember correctly) and would do so again. Note that it is recommended that the vent extend 3' beyond the outside surface of the wall.
My unit uses inside air for combustion. I've sprayed lacquer with a box fan exhausting under the partially-open overhead door. I turned the heater off until the cloud of vapor was removed by the box fan -- about 2 minutes -- then turned the heater back on. No problem.
The most difficult part of the installation was getting the heater hung on the ceiling. A helper and I balanced the heater on top of a step ladder and the helper only had to bear the weight of the unit for a short time while I installed the four lag screws.
I'm happy with the heater and wish I had bought it sooner. Makes working in the garage/shop much nicer in the winter.
Al
Re: Mr. Heater
>Reading Pat's post reminded me that my heater is a Mr. Heater, not a Hot Dawg. I looked at the Hot Dawg for a long time but, when it was time to buy couldn't find a nearby dealer who'd sell me the heater at a reasonable price. I, too, bought the Mr. Heater at Northern Tool along with the vent kit.
Sorry for the confusion.
Al
