Cutting 6x6 treated lumber
John Halstead
>I am having trouble cutting 6x6 treated lumber that is stil damp in the center. My hand held power saw with a combination saw blade will not do the job.
John Halstead
Re: Cutting 6x6 treated lumber
Dale Lenz
>Are you trying to make the cut in one pass? If so, make several passes of say 1" deep per cut, flipping the cant over every cut.
Rob Stokes in North Vancouver
>Sounds like a perfectly good excuse to buy a worm drive :)
Rob
Re: Or a husky, : ' >
Dale Lenz
>Use a sharp thin kerf blade. Square all the way around the timber and cut from all four sides. Still might be about a 3/4" square in the center to cut with a hand saw.
I have an old B&D Sawcat and it will do it. Perhaps your saw doesn't use enough amps. If you have a lot to do, it might be time to upgrade to a really heavy duty saw. Can't think of a real good reason to resent having too much power. Too little is a different matter.
If the cuts don't have to be too pretty, a small electric chain saw will handle them quite nicely. Another nice tool to own. (about a hundred bucks)
Glenn Madsen in the SF Bay Area
>And if there aren't too many to cut, and money is a concern, a sharp crosscut Disston will be useful as well.
I LIKE the chainsaw idea, though.
Bow/Swede saw another option
Bill Howatt
(snicker-snicker !)
steve mackay
Good thought.
>I had one when I was a kid that would have made short work of them. It must have been made in America or maybe Sweden and it cut like crazy. The ones I have tried lately were cheep poor quality knock offs and were not worth owning. So if you try this route look around for a better quality one.
Sawzall another option
howard
