OT Gas wells
OT Gas wells
OT Gas wells
Sawman
>Looking at the possibility of a gas well. Presently I use propane. Part of the deal would be free gas about 250,000 mcf per year. How can I compare that to gallons of propane?
Also any advice from those who have had a well installed?
Re: OT Gas wells
Re: OT Gas wells *LINK*
>MCF is ~1000 cubic foot at standard temperature and pressure.
Use the calculator. You've got a lot of natural gas.
Fuel Equivalence
Re: OT Gas wells
Re: OT Gas wells
Brian in Brighton
>How will they get it back to you? You can't just use it straight from the hole. We have a gas well across the street and there are processes that need to remove water vapers and other contaminates and add the smell.
If they provide that much gas for free, I would look into how much money for the leasing you are getting. Maybe they will just give you whatever your home ever needs?
Brian in Brighton
Re: OT Gas wells
Might be time for a new pickup truck.
Basil
>Of course the bed will be full of compressed natural gas tanks but hey, you'll be riding for almost free.
Re: OT Gas wells
Had one on my land
Ray Thompson - Middletown,IN
>but it got cemented in just before I bought the place, rats. Around here there is plenty of natural gas and it takes about $25,000 to drill the well. I considered it but discarded it quickly, my neighbor drilled two wells and came up dry both times with working wells on either side of him. It is used straight out of the ground, but you have to have the water pumped out every so often, every year or so. My aunt and uncle bought their place (here) in 1960 and the house was not only heated with gas but all the lights were gas that folded out from the walls. The original well was dug in the twenties (500') and was used continuously until the mid ninties when the pipe finally rotted out and they could not afford a quarter mile run to the well so it got cemented in. Another neighbor has one and he heats not only a 4500 sq. ft. house but a 40 x 64 pole barn as well.
Ray
Re: OT Gas wells
Are one of the land owners in N AR
Keith Newton, LR, Arkansas------WebKitFormBoundary
>who owns their mineral rights on their land? I hear there are a lot of folks up there who are getting as much for the mineral rights as the land is worth.
If you own the mineral rights for a well that will produce that much NG, you are sitting on the proverbial gold mine. I wouldn't worry about how much I used, just how much I could get from selling it.
On the other hand, I had an uncle who had some oil wells that back when I was a kid, they just burned off the natural gas that came out. But it left a condensate that my cousins would collect and fuel their cars with for free when we were teens. I think they called it case-in-head or something like that. It smelled weird, but they knew how to soup-up their cars for it, so I was impress with the power they got
Re: OT Gas wells
Re: OT Gas wells
Larry Clinton At Frankfort (Central)., Indiana
>Looking it up on the net - 1 MCF (1000 cubic foot of NG) equals 1,020,000 BTU. Since LP (Propane) equals 91,547 BTU per liquid gallon, and you estimate 250,000 MCF the conversion would end up that you could produce the equivalent of 2,785,454 gal of Propane. At wholesale wellhead prices around $10 MCF (depending on time of year and location you are looking at well over two million dollars of gas/year.
Re: OT Gas wells
Re: OT Gas wells
John in Calgary
>I use between 5-15 GJ of gas per month (approximately the same as an Mcf or 1000 cubic feet) to heat my 2400 square foot 6 year old house, that includes gas for the stove and dryer, so expect to use 100-120 Mcf for a year - 250 Mcf is a reasonable limit. If you also heat uninsulated barns, sheds or shops, you can add to that.
As noted above, if you are the mineral rights holder, look into getting your share as a royalty instead, that way you can share in the upside (or downside), but be careful of the terms as there was a time when you got your royalty check net of expenses, but if the gas prices tanked, the terms of the agreement meant that you were upside down on your share of royalties and you actually got an invoice instead. Do a search on Alberta Freehold Royalty, there is some good background info that may or may not apply in your situation.
If you are taking gas in kind to heat your house, make sure you include treating, dehydration, dewpoint control, odorizing, transportation to your house, or whatever else you can negotiate to minimize your own up front costs to use the gas. You will also need to convert your furnace, gas fireplaces and any gas appliances, which is usually just an orifice change out but might not be. Also make sure there are no government royalty implications to your taking the gas for free (I've heard it called Ad Valerum taxes in the States, but not sure if that is correct) or personal income tax or gas co-op implications, your free gas might not be so free.
Lastly, as a surface owner, be warned that drilling a well and pipelining tends to be a much messier adventure than you think for a first timer - the negotiator will promise you the world, but drilling and pipeline crews tend to do whatever they want, so make sure you include adequate compensation for your own hassle, and include fees for trespass, garbage clean-up, etc.
John
(I work the other side of the fence, and usually have to live with the consequences of the singular focus of the pipeline and drilling crews!)
Re: OT Gas wells
Re: Had one on my land
Dick Coers
>Ray, Wouldn't concrete be an easy drill if the casing was still good? I know concrete would be easier to drill than hard rock, but maybe still too expensive to make it pay off.
Re: OT Gas wells
Re: OT Gas wells
Grant in Iowa
>An acquaintance of mine has a farm in Ohio and he has a 30 year old gas well on his land.
From what he told me, his agreement is such that he uses all of the gas he needs for his home and also gets 1/8 of the revenue in the form of a periodic check. He said his father (who owned the place prior to him) didn't have to pay for any drilling or set up.
He did say that the gas company still has to visit weekly to pump water out of the well and check on it.
Even without a revenue check, I'd think you would be money ahead to just get free gas.
FWIW,
Grant in Iowa
