OT: Poured foundation depth (rat entry problem)
Dan Mitchell
>We bought a house a little over a year ago with a history of rats in the crawl space. Terminex guy contracted by former owner provided a paper saying "no current activity". An independent exterminator I hired after the purchase said the same. Since that time, I have trapped 6 rats down there. I have very carefully inspected the perimeter of the house and despite locating & sealing off 3 pretty darned (wanted to use another word there... ) obvious entry points around framing etc. which the pros missed, they're still getting in. I'm wondering if they might conceivably be tunneling under the poured foundation & coming out inside through the dirt floor. Generally speaking, how FAR DOWN below the outside soil level would a poured foundation go? The property slopes from front to back, ground level at the rear is probably a good 4' below that in the front. If the code is for the foundation to go X number of feet below grade, I'm assuming it would have to be 4' DEEPER in the rear, correct?
Any helpful insights appreciated.
Dan
Re: OT: Poured foundation depth (rat entry problem)
They may not have to dig.
Eddie Pacheco; San Jose, Ca.
>They could very well be coming in through a gap in your main garage door or side door, and getting under the house through a gap in a garage wall. It doesn't take much of a gap for rats to get through. They won't do anymore work than they have too, so if the garage access is out there must be some utility pipe that comes through your foundation that has a gap around it. This will probably be located in some nasty, scary part of your crawl space. Good luck.
>Hi Dan,
Locally the building code calls for the footings to extend below the frost line and to undisturbed soil free of organic matter. That used to be about 14" here and through the top soil, which is worn out and thin in most places, so, about fourteen inches was it.
Then we ran into a huge area of shrink swell soil and they decided two feet deep would be better.
Further south, they don't have to worry much about freezing and slab houses are popular. North of here, the frost line is much deeper and they have to go down four or five feet, thus they have basements.
I have heard about houses with thin slabs poured under them in the crawl space as a "rat slab." That is, expressly to keep the rats out, but I have only ever seen one.
I agree that rats are lazy and opportunists. They may be borrowing the work of other critters such as moles or ground hogs, or chip monks or Meir cats. Anybody else in your neighborhood digging for a living?
Keep looking and keep trapping. And Oh yeah, the footing step down around your house so they should be a fairly consistent depth below the surrounding soil.
Steve Schoene
>Depth depends on where you are. In Southern climes foundations only go 12" deep but in frosty regions they go below the frost line, as established by code. In CT it's 42" I believe. Foundations can step down the slope so they don't have to be that much deeper on the high side than the lower.
Re: They may not have to dig.
Dan Mitchell
>Eddie - Nasty & scary is right, the whole damn place gives me the willies. There's no experience quite like the 1st time you look over to where you know you placed a trap, only to see it's gone. With a shiver up your spine, you crawl (it is a CRAWL space, after all) over to the spot where the trap landed after "deployment", and find a big fat rat torso sticking out of the trap (I use the aptly named black plastic "T-Rex" traps, so the rodent always looks decapitated). I'm getting a bit used to it, but it's still pretty creepy.
The garage & house aren't attached, but there is an area where the main water drain exits, naturally, as far as possible from the entry door, and I do think that may be a possibility. I'm thinking of packing the area with cement, but mixing it on the spot is out of the question & dragging a tub of it over there will be a challenge.
Dan
Dan Mitchell
>Steve & Barry - Thanks for the replies. I'm just north of Seattle, so while it rarely gets real cold here (or real warm either. Or real sunny. Rains like hell, though... ;-/ I would think there is a "frost line". I wonder if the county building code people could tell me?
Dale Lenz
Re: OT: Poured foundation depth (rat entry problem *LINK*
Dale Lenz
>For sure check with the county. Link below indicates 18".
Frostline in Seattle
>Dan, for clarification, you said you had trapped six (?) rats in the crawl space? What are you doing with them?
Locally I run into squirrels in attics. The answer is in two parts. Seal up their holes with something they can't chew through and either kill the squirrels or transport them a lllooonnnnggg ways away, maybe ten or fifteen miles. Two or three miles won't do it, they just come home.
Once they are in the attic, sealing the hole is not enough. They will chew another one. So, you have to remove the knowledge base from the population. Kill off or transplant the ones that know the secret.
While I personally have little compunction about killing rats, the cute ones have to go away, far away. So if you have been doing the humane trap and release, you may have been catching the same rat over and over.
Eliminate the food source
Lee Schierer - McKean, PA
>One thing about all rats is that they have to eat. If you eliminate the food sources nearby you will eliminate the rats. They won't live where they can't get something to eat and they generally don't venture far to get food. Locate the food and eliminate it and your rat problems will end shortly.
Lee
Dan Mitchell
>Barry - Yup, six rats. Lovely.
The only thing I can think of that would be creepier than encountering a dead rat in a trap is a LIVE ONE in one of those "havahearts".
OK a live one stuck to a glue board would be worse...
Nope, I'm using T-Rex snap traps.
Snap, as in "their miserable little heads off" ;-)
Re: Eliminate the food source
Dan Mitchell
>Lee - I completely agree, it's one of the things that confounds me about this situation. They're not getting food from our house, we don't have a pet, no bird feeders, etc., and there's not really any "unsecured" garbage etc. in the area. The lot is pretty big, about an acre, so the closest neighbor is some distance. One person across the street has a small dog, which they may be feeding outside, but if so, you'd think they'd be over THERE.
The only thing I'M giving them is generous amounts of commercial poison in 7 bait stations.
The lot is heavily treed, mostly conifers. I'm not sure what natural foods might exist in that environment. The VERY abundant pine cones seem like a possibility. If that's the food source, eliminating it would be all but impossible.
2 neighbors I know of have had roof rats. Most people never go in their crawl spaces, even if you do, you have to know what to look for. I wouldn't be surprised if most of the houses have infestations.
Dan
Hamish
>It seems that your rats like their abode under your house, dark warm and cosy. Why move!!
Fred Davis
>Dan ,
A effective rat barrier for chinking cracks around pipes and plumbing and wireing chases is Steel wool, much easier to transport then "dragging a tub of cement".
Acceptable to building inspectors as well.
Your commercial Rat poison besides killing the rats, has a deadly secondary effect on anybody's dog or cat that eats the dying or dead rat.
FredD
Re: Copper "wool" *LINK*
Kneale Brownson Dreaming of the Snow in N. MI
>Most pest controllers would use a copper mesh instead of steel wool to plug up cracks and holes. Doesn't rust and stain like steel wool and it's more coarse. The link goes to one example
copper wool
Re: Copper "wool"
Fred Davis
>Copper would be cool , but since the plumbers only carried the steel wool , that's what we used.
FredD
