metal+wood= barrettes?
Kimberly
>I'm trying to find out the best way to attach a metal barrette to the wood. I tried CA glue yesterday, and this morning a dropped it (about 2 feet) and it popped off. Any suggestions??
Re: metal+wood= barrettes?
steve mackay
>Hmmmmmmmm, use the Dremel to cut a shallow inset then epoxy ?
Re: metal+wood= barrettes? *LINK*
Bill Roland (Mt Juliet, TN)
>Try this link.
Thistothat
Kimberly
>Thanks Bill. I will try that!
Kneale Brownson Dreaming of the Snow in N. MI
>I have a friend who makes cabinet door and drawer handles by gluing Petoskey stones to cabinet hardware base plates. He uses common two-part epoxy.
I had to Google that one!
Neal in San Jose
Jim Pugh, Elyria, OH
>Kimberly,
Many years ago I made some barrettes for a daughter and a bunch of wood belt buckles for myself. The most foolproof glue I have found is Weldbond. I found that epoxy didn't make it for very long - like maybe a couple of days. The Weldbond will occasionally let loose but it will usually be after years of hard use. Then I just cleaned up the surfaces and glued them back which was good for more years. It dries clear. Good clamps to use while gluing are rubber bands and or spring type clothespins. Hope this helps.
Steve Kreitler
>I've made lots and lots of wooden barrettes (even had a short article on it in Creative Woodworks and Crafts some years ago). The only glue I found that would work with the metal barrette clips was E-6000, which is sold at pretty much all the craft stores. I don't like the smell, but that stuff sure does hold! A glued up barrette I gave my wife ten years ago has started to delaminate- but the e-600 is still holding well!
The only other thing that worked for me was to put tiny screws through the clip into the wood.
Kimberly
>Well, I have a lot of thinking to do! Thanks guys!!
