Quarter Sawing
Quarter Sawing
Quarter Sawing
Ron Bauman
A few weeks ago I ordered some Quarter sawn White Oak from a local mill for a table commission. Since I was also working on some photos for my new website I asked the sawyer if he would mind my taking shots while he was sawing. "Come on ahead. Sunday OK with you?" The above shot is an oak log approx. 26" dia. by 8'6" length being loaded onto the saw.
Above: the saw starting the first cut, halving the log with the blade set just above the pith.
above: Finishing the first cut, the blade exiting the log.
Above: The sawyer's "aide de camp" pushes the halved log onto the skid loader.
Above: The halved log is oriented to make the first cut into quarters.
Above: The top quarter of the log on the floor. Note the fleck on the two exposed faces.
above: This shows the saw blade entering the quartered log for the first actual "quarter sawn" cut.
Above: The saw completes the first plank cut.
This is the first plank for the table. Note the pith to one side which will be removed when the plank is sawn to size. The tree from which this log was taken was on the site of a new construction and may have been cut and discarded had not the sawyer bought it and removed it. This is his specialty, saving trees from construction and road building sites.
Re: Quarter Sawing
Picture problem
Dan Donaldson
>It looks like either the picture hosting service does not allow direct linking, or they limit the number of views and it has been exceeded.
Re: Quarter Sawing
Sorry will re-post this evening .......
Ron Bauman
>when my techie son gets home.
Re: Quarter Sawing
Re: Quarter Sawing
Rick in Colgate, Wi
>Worked for me! Thanks for sharing.
Re: Quarter Sawing
Here's the re-post. Hope this works!
Ron Bauman
loader.
two exposed faces.
Re: Quarter Sawing
Dale Lenz
Re: Thanks for the repost, Ron.
Dale Lenz
Re: Quarter Sawing
It is a lot more fun when,
Keith Newton, LR, Arkansas------WebKitFormBoundary
>the logs are a lot larger than that. I like to get them too large to go on my mill, then rip them down the middle with a big chain-saw. When each quarter is as large as that full log, the yield of QS is better. Not to mention the excitement of seeing planks in the 20" range.
