THE WOODRAT IS BACK!
grinding jig
grinding jig
grinding jig
les winter
>I bought this grinding jig on Ebay. It's similar to the one I have attached to my grinder: that one is mounted on an adjustable arm bolted to the side of the grinder. This one fastens to the bench.
I don't know what the T-shaped steel part is used for. Anyone out there know?
thanks,
Les
Re: grinding jig
Re: grinding jig
Jim Toews - Walla Walla, WA------WebKitFormBoundar
>Les,
I don't actually know what it's for, but could it be a short blade holder of some sort? For holding spokeshave blades and the like. Just a guess...
Cheers!
Jim
Re: grinding jig
Re: grinding jig
John S
>It looks to me like the main platform can be pivoted to various angles. Could it be that the additional "T" jig is to use for squaring the platform back to 90 degrees?
John
Re: grinding jig
Re: Ask the seller?
Al Stokka - Cambridge, Iowa
Re: grinding jig
Re: grinding jig
larry in kansas
>Les The eaisest way but it takes awhile is to put it aside for a year or so and then one day throw it away and I`d bet my unisaw that the very day the trash haulers pick it up someone will see your grinder and ask you where the tee thingy is. NEVER fails. Larry not in Ohio
