water pressure (OT)
water pressure (OT)
water pressure (OT)
larry in kansas
>I live on town water and it seems that the presure is not very good. Being that everything is good, is there some way that it can be boosted say about ten more pounds or more. I`d like to get it up around 60psi. I think that is about where it should be. Any and all ideas and opinions welcomeThanks. Larry somewhere in the Southeastern part.
Re: water pressure (OT)
Re: water pressure (OT) *LINK*
Kneale Brownson Dreaming of the Snow in N. MI
>There are pumps that can be inserted into your municipal supply to increase pressure. The link goes to just one of many.
Pressure Pump
Joseph Mulherin, Sr.
>Larry, is your home equipped with a pressure regulator on the inlet from the street? If so, then it just needs to be adjusted. Loosen the locknut on the stem and turn the shaft in until you get what pressure you want inside, then re-tighten the locknut. If not, then you can purchase the auxillary pump mentioned to increase pressure. I would check with the Water Dept for your city first to see just what pressure they are supplying to you.
John Veerkamp, Western Mo.
>AS was mentioned, there are pressure increasing pumps out there. Do check first on your system to be sure there isn't a pressure regulating valve on your line. It may be faulty or set too low. Also check the specs on any appliances. Some dishwashers and washing machines can't have pressure as high as 60 lbs.
John
>Although we are both on the same county water system and both live on the tops of hills, my friend and I both experience different water pressure - mine is fine and his is low. He added a booster pump which did the trick.
larry in kansas
>Thanks for the advice, I`ll start working on this when we get home. I`ll start with checking our pressure, can I use an air pressure gauge for it, and look into the pumps. Can someone give me some web sites. Thanks again. Larry
50 psi should be more than adequate
Tim Greif - West of Chicago
>Are you sure what your pressure actually is? I run 57 psi consistently and have absolutely no need for any more pressure. It's plenty adequate for a two-head, 2nd floor shower. What you may have is a restricted supply line that lets the pressue drop due to friction loss during high demand periods. You can pick up a cheap pressure gauge at the hardware store along with a couple brass fittings to adapt it to your garden hose connection.
Check the pressure with no water flowing, then see what happens when you turn on the washing machine, flush a toilet, turn on a shower or run the kitchen sink faucet. You'll see a pressure drop that results from the friction loss in the supply line. But it should not be excessive. As an example, my static 57 psi drops to just under 50 when both the kitchen faucet and the washing machine are on.
Give me some more details and maybe I can help. In my day job, I play an engineer in the water and wastewater industry.
Pete in Holland, MI
>Are we talking pressure or flow here? Most people refer to not getting a lot of water out of their taps as "no pressure". As noted in other posts, get a pressure gauge and see if you have 40-50 pounds of pressure in you lines with all the taps turned off. If when you start flushing toilets and running sinks that the pressure significantly falls off, then you have a flow issue, which relates to all pipes coming in off the street, any point could be a restrictor.
Have you an old house with galvanized pipes, or a galvinized supply line off the street ?
Re: 50 psi should be more than adequate
John in Calgary
>I was going to say that should be lots of pressure - I checked with the city when I went to design my watering system for the yard and they indicated that the pressure in our area was in the 35 psig range.
As Tim mentions, make sure you check the pressure at both static (no water running) and flowing conditions so that you can see if it is in fact a restriction up stream of your house/meter/regulator/etc., or if its just a restriction at the tap.
John (who doesn't recommend that you let an engineer design your underground sprinkler system, no matter how helpful they seem, or how well you know them - I'm still kicking myself for my own design!)
90 Here!
Tony - Memphis
>Wow, I checked mine and it ran 80 to 90 psi. A buddy of mine had all sorts of issues and bought a gauge. His ran 120psi! He put in a regulator. I was curious, so I borrowed his gauge and checked mine. I've not had any issues, but I was curious.
Tony
Jim DeLaney, Austintown, Ohio
Re: 135 (unregulated) Here!
>I have a whole house regulator to take it down to 60 psi, and an expansion tank for the water heater, since the regulator acts as a 'one-way- valve, and will let back pressure build without the expansion chamber.
larry in kansas
>I`m on vacation right now, but when I get home, next week I`ll do some checking. The house is only 29 years old and all copper. Would an air gauge work to check the pressure? Keep the ideas coming, they are all good that I didn`t think of. Larry
>As a Home Inspector, I used to carry a pressure gauge. (It's still hiding around here, somewhere.) What I found was most people don't really care what the pressure is. They want to know what the combination of pressure and flow is. (Can I take a shower while someone else is using the water and not get burned or frozen?) Now, my highly sophisticated test is: turn on the shower, Look at it to see the output, flush the toilet and run the sink simultaneously, and observe the flow from the shower. If nothing or nearly nothing happens, good to go. If the shower out put drops dramatically, not good.
Did a house inspection on a house with very poor pressure. An old guy from the city comes out and hooks a hose tot he outside faucet. Hose had about a three foot piece of pipe on it. Points the hose up at about a forty five and turns on the water. Water went up and out about 18". Yup, lower volume and pressure. I asked, how do you know? His answer was that if it had been good it would have shot the water ten or twenty feet.
You really don't want the static pressure to be very high. Its very hard on toilets and the stuff with solenoid valves like the dishwasher and washing machine. In the case I mentioned above, they replaced the main into the neighborhood and almost everyone had to rebuild their toilets and replace solenoids. They were angry about having better water pressure. Fifty pounds is plenty if you have enough volume. Many systems on wells have a pressure switch that runs between 20 and 40 PSI.
Have you checked to see if your main valve and the one at the street are fully open? I have found a number of houses where they were nearly closed and that restricted the flow.
Joseph Mulherin, Sr
>Larry, are you asking if a tire air gauge will work......NOT....
go to the local Borg and buy a small water gauge that you can attach to the outside faucet. Then have someone inside open various valves and operate the appliances and watch what happens with each application. Since your house is only 29yrs of age you shouldn't have these problems. Like I said, first check with the local water district and see what pressure you should be receiving. If things are really nasty, you might have to setup a system like they use on a farm or ranch using a well and have a pump and storage tank. Good luck.
