LEIGH FMT mortising jig question
charlie belden
>(I'm posting this question to several woodworking forums in hopes of getting
an answer. So if you've seen it before, apologies)
I'm studying the LEIGH FMT mortising jig and the question of registering
the part that will be end grain mortised to the plane of the jig's table has
come up.
It appears to me that the only way to register the part to the jig's table
is against the little pull out "cross hairs thing". THAT is not very much
surface to register against - and that registration is really important.
If the part ends up just a little high or just a little low - or tilted left or
right - just a little bit - it can result in a bad fitting joint.
It looks like the jig table can be moved foreward and back - but the range
of motion appears limited - and it's not clear if the jig table can be slid
foreward enough to let you register the end of the part to be mortised
against it. So if you've got the LEIGH FMT jig - CAN you slide the jig's
table foreward enough to use it to register the end grain mortised part
against?
If it can't, is this actually a significant roblem - and how do YOU solve it?
charlie b
