Defaced Double Dresser Top-BUMMER
George W. Dart-Havertown PA
>Good Afternoon Friends,
I planned on wet sanding The new double dresser today, and armed myself with some oil, naptha, felt block, paper towels, and sandpaper. The dresser is out of the shop and on our screened in back porch where its out of the sun, relatively cool, and light enough to work in quiet comfort. It has rested in place for several days while the shellac Seal Coat dried and hardened. I usually give it a couple coats, wetsand, inspect, and begin the wiping poly top coats. After wetsanding the top, I wet a towel with naptha and got rid of the residue. Then I noted someone had attacked the right rear of the top with repeated strikes of a pointed instrument, putting shallow dents and gouges perpendicular to the grain. Several times the pock marks went deep enough to expose the raw cherry. The area is about 18 inches long and perhaps 2 inches wide. I "lifted" the residue out of the depressions. In about a third of the damaged area, the wood fibers were severed, and the rest are dents which may be too deep to steam. In any event, I'd have to sand it all out, feather, and blend into the undamaged portion of the top. Fortunately, Seal coat only has thus been used in the finishing schedule. No poly has yet been applied. However, I had set the piece out in direct sunlight for a week or more to darken. Now that red color will be sanded away. Or, maybe I should sand down the entire 48"X18" top and start over as before. My wife suspects my oldest grandson because she noticed he was playing with a pen on the back porch a day or so ago. His Mom, my #1 daughter will find out. But now I have to figure how best to salvage the once perfect top. What do you think?
George
