Re: Need sanding advice
Richard Jones
>What I do.........
I use the velcro pad from my sanding disk and chuck it in the lathe. It's much easier to hold the piece and take it to the sandpaper than the other way around.
If no lathe, you could do the same thing with a rigged-up foam block chucked in your drill press.................
A drum sander always seemed too hard-backed to me, but it may work for you. The foam in a sanding disc pad seems a bit softer.
I make lots of jewelry, earrings, etc., this is the easiest way that I've found. Speed with a 2" disc is around 400 max.
Let me know if you need more info, and good luck.
Rich in VA
