Black Pipe and Paint?
Sawman
>Getting ready to install a black pipe air line in my shop and would like to paint it afterwards. Has anyone painted this product and if so what kind of paint did you use?
Thanks
Re: Black Pipe and Paint?
Lee Schierer
>Almost any paint will work. Semi-gloss or gloss will be easier to clean off than flat. Be sure to wipe the pipe down with a rag and mineral spirits as the threading oil can make the paint not stick. Note that paint on the threads will make future pipe assembly more difficult.
Lee
Jason Roehl in Lafayette, IN
Be sure to prime...
>If you're wanting to paint it with a waterborne product, you'll need to prime it first with an oil or other solvent-based primer (shellac, xylene, etc.). There are even some specialty WB primers that would work. Otherwise, the WB topcoat may show rust spots. Or, you could go straight oil-based paint, but remember that any light colors will likely yellow over time.
Jason
Roy Anderson
>I agree totally with Lee. Inside your shop any paint would work. Black pipe inside your shop will last very well, so painting is cosmetic. Be sure to remove any pipe dope left exposed on the threads.
I just painted my exterior gas line at the meter with a rust preventative flat primer. If you really wanted to over-do it you could paint first with a rust preventative flat primer, then a high gloss top coat.
Or you might paint the first coat with a flat institutional green and the top coat an ivory crackle coat, so it would have an antique look....Just kidding.
Justin
>I'd say your best bet is to go to a paint store (not a paint department of a big store) & explain to them what you want to do, how much you want to spend, & they can give you a product to match. Sherwin Williams has good industrial finishes, & they have a direct to metal (DTM) water based acrylic exterior house paint that is pricey but may save you a step or two.
Peace
Justin
Larry Clinton At Frankfort (Central)., Indiana
>I have an exposed 3/4" NG pipe running up on wall of my shop with elbows, valves other fittings (feeding the furnace upstairs). I removed the excess pipe joint compound at the fittings, the pipe was clean enough (no rust) that I just painted over it with the same waterbased latex paint I used on the walls. Varathane (woodsmoke color) It has held up perfectly, no bubbles - flakes discoloration - in the approximately 3 years it has been there.
Rustoleum *LINK*
Michael Dresdner
>Anything in the Rustoleum Stops Rust line, or their newest paint, Universal, which does not even require primer.
Universal
Pete in Holland, MI
>Oil based primer for steel is a must to prevent rust, even inside. Water based paints will start the rust process. Once it is primed with an oil based product, you can top-coat with anything you desire.
