Have a question? Ask Woody!
Barrel nuts...for knockdown legs... *LINK*
Alan Young
Alan Young
>I started a thread a day or so ago on a dowel jig-that turned to discussion on knock down joinery---That thread is linked below...
Here is a continuation regarding fabrication of the nuts...
I drilled and tapped some 3/4" cold rolled steel for a 1/2-13 rod.
I did not implement the counter sunk portion to accommodate a fastening screw. These barrel nut are 1.5" long. The rods are 6" which will leave 4.5" inside the body of the leg-that should provide sufficient stability.
I also turned small "epoxy gripping grooves" on the outside of the nuts and I gave each a slight taper on one end to aid in inserting them when the time comes...
Alan
Thread on a dowel jig and knockdown joinery
Re: Barrel nuts...for knockdown legs... *LINK*
>Wow! Your metal working skills are clearly better than mine.
I posted a response to your previous post. I thought barrel nuts were made with the hole going through the steel rod the other way, at ninety degrees to the axis of the rod. At least that is the way I made mine for the bed I made. Then you drill a hole in from the the side of the leg and insert them, glue them in so they don't float around and fill the hole. Or you could chop in a rectangular mortise and insert a nut into the leg. This would give you metal on end grain to pull against.
In your design, the bolt is trying to pull the nut out of the hole and the epoxy is holding it. I am a little suspicious of the epoxy over time, say the next hundred years.
For the all-thread in the other portion of the leg I would thread the hole in the wood, slather the threads with epoxy and screw them in and then pin them through the side of the legs.
It's personal, but I just hate relying on Epoxy. I turned some canes out of gorgeous walnut and glued brass heads on them with epoxy. They fell off under their own weight. Bad batch of epoxy, buy how you going to know and how you going to fix it if it fails?
Alan Young
Not finished yet ...
Alan Young
>Barry-
I am sure you are correct regarding the term "barrel nuts".. A phrase I only discovered in the course of this and the previous threads. I guess I did not understand the methodology as stated regarding the term. And I agree that the long term holding power of the pieces as I have them so far is suspect- that's why part of my original design- had the nut held in be a counter sunk screw....
What I did not mention in the post above is that I plan on gluing these in(epoxy) then drilling a hole through the inside section of the case work and what will be the "upper" part of the nut. I will then insert a metal pin through the case/nut and rod. This pin will prevent the nut/rod assembly from turning over time...
I am attempting to follow Ellis's lead and over engineer to a maximum effect...:^)
Alan
Alan Young
PS....
Alan Young
>Well a quick search under the term barrel nut clearly illustrated the device as you described...
Alan
Alan Young
Extremely slow thinker....
Alan Young
>Well duh! That pin will have to be removable-ie the side ways hole has to be tapped and the pin must be a remove able screw. Otherwise the entire exercise in providing a "knockdown joint" is moot I need more coffee :^(
Alan
