trunk design question
Bill Tindall, E.TN
>Do trunks typically have some arrangement for aligning the top(lid) with the bottom when the top is in the closed position, for example, a thin molding around the top that would lip over the bottom in the closed position, or interlocking rabbits where the top and bottom join? Or is it sufficient to just let the hinges align the top with the bottom which is what I would do on a small box?
Re: trunk design question
>Good Afternoon Bill,
Its YOUR design. Why not have a piece of alignment molding lip under? I think that is a good idea. Ive done a couple trunks and blanket chests, but relied only on hinges and hasps to do the job.
George
John McGaw
>Old trunks that were designed to be moved frequently (think "steamer" trunk) frequently had external metal fittings to align the lid with the body, not to mention metal corners and handles. When I've built Shaker-inspired blanket boxes and chest on drawer pieces I've dispensed with such alignment aids completely since the lids were invariably larger than the bodies. In designs where the lid is thicker and the same dimension as the body some sort of internal alignment aid would seem appropriate since having them move out of alignment would be immediately evident and jarring.
>That would depend on what type of hinges you're planning to use. If you use something like the side rail hinges with stops at 95 degrees, they sort of self align - and you won't have to put in a set of stops.
The chest hinges act in a similar fashion.
http://www.rockler.com/product.cfm?page=424&filter=chest%20%20hinge
http://www.rockler.com/product.cfm?Offerings_ID=1663&TabSelect=Details
