Basement window repair...
Tom
>I posted in winter about the wisdom of filling in a leaking window well, and was dissuaded. Well, the weather is warm and the rain is hard and I've got to stop the leaking. Is there any chance of plugging the gap between the window bottom and sill with some sort of cement, silicon, vinyl cement path or roofing tar? My first though is to pack it with vinyl cement patch and then layer it in roofing tar when dry. I have absolutely no idea if that is a good or bad idea though...Any thoughts? I'll try and post a few pics of what I'm talking about.
Re: Basement window repair...
inside
Tom
>and an inside view...
Lee Gordon
Re: Basement window repair... *LINK*
Lee Gordon
>You can get foam filler rods (they look like dowels but made of insulating foam) and stuff them into the crack, then parge over that with a product like Quikrete Concrete Repair.
You could also use aerosol spray foam insulation but you'd want to get the minimally expanding kind.
http://www.quikrete.com/ProductLines/ConcreteRepair.asp
Justin
>The best thing to do (besides removing the window & framing a new opening & installing a vinyl window) is to use Geocel caulk to caulk the seam between the window & the concrete. Nasty, thick, gooey, rubbery, smelly & I was told it can be installed on wet surfaces. It is a great product for situations like this. Clean the area thoroughly, get the dirt off, backer rod if needed, then pump on the Geocel. Or a wet stop caulk roof repair caulk. That should hold the water out for a while. But the water, unless persuaded to no fill up the window well, will eventually find it's way in again.
Peace
Justin
>Tom, As a Home Inspector, I look at this differently than some.
Every water leak has three components. A hole for the water to go through, a driving force that makes the water go through the hole such as gravity or wind, and WATER. If you remove any one of the three parts, the problem goes away.
If I understand you, your widow well floods or partially floods and water runs in through the or under the window.
If you can seal the holes perfectly, the well will flood deeper and you will have what looks like an aquarium from the basement. Sealing the holes perfectly would be very difficult even with truly excellent caulk.
If I were trying this, I would look at taking away the water. Can you improve the grading around the window well to make the water run away. (IE, make gravity work for you) Gravity is relentless and you really don't want it working against you. This might be good for the house and basement as well. It could take truck loads of soil, but I often seem settlement around houses that has been there a long time and it takes an astonishing amount of dirt to fill in the sunken areas. OYOH, I did this about a year ago on a rental house I own and I bought a truck load of clean shredded or sifted soil and had it dumped. Took less than a day to spread it. Created at least six inches of slope at the foundation for the first six feet.
If it is rain water falling into the wells you can buy covers for them at the Borgs.
Another approach is to dig a hole in the bottom of the wells as large and deep as you can and fill it with gravel. Try not to beat up any water proofing that might be on your basement walls. Hopefully this will do two things, serve as a sump to hold the water until it can soak away and get it closer to the footing drains so it can run away. Here's a stray thought. Rent a power post hole digger/auger and drill a deep hole either in the window well or outside of it and put a piece of perforated plastic pipe in the hole and gravel outside the pipe. I expect the hole will have to be outside the well and you will need a buddy to help, but this might serve to lead the water out of the well and give it somewhere else to go. Needs to be deeper than the well. You could do one or two with a manual digger. Call Miss Utility or whoever before you dig.
And, you can still caulk the window, but the key is to not rely on caulking. Chase the water away.
Lee Schierer
>I agree with fixing the problem. If you want to patch, there is an excellent patching material called Pro Wet Plug that is a cement type product that will seal the area and allow you to trim it out like mortar.
If the window is not opened, then I highly recommend installing glass blocks. They let the light in, but will keep the water out even if the well fills with water at some point. They aren't that hard to do and they last forever. They will also make it near impossible for a theif to get in and add insulation value to th windows.
Lee
Caution if replacing window....
Tim Greif - West of Chicago
>I can't tell from the pics if this is a tall window in a deep window well. If it is, you may not be able to replace it with glass block and still be able to meet code issues if you later try to sell it. Most building codes nowadays require a second emergency exit from a basement, and that's usually the window well with a quick release window frame. That's what I have. Just a thought.
I'd deal with eliminating how the water gets in there in the first place. Hinged plastic covers, re-grading, downspout relocation, etc.
More info...
Tom
>Thanks for all the answers so far... I've tried well covers, they're useless for me. As you can see from the photos, digging outside the well won't be possible. There is a slight grade on the cement on it, neutral at the worst. I may have to look into cement raising, or whatever it's called. That sounds expensive:( We've been in this house for 6 years now, and it's only the last two that we've had this problem. I guess I'll need to try and dig it out farther too, before patching and/or hiring to put in glass block (which sounds expensive too:(). Any more advice is certainly welcome...
Re: More info...
Tom
>and one more...
Re: More info...
Kneale Brownson Dreaming of the Snow in N. MI
>I'd take a post hole digger to the bottom of the well for as far as I could get and then refill with gravel. What's the soil condition there?
Larry Marker
>I totally agree that the solution is to either get the water out of there or don't let it in.
How big is this well length X width? A sheet of acrylic cemented to the well with silicon caulk might be enough. An alternative would be a small sump pump.
If this isn't an emergency exit, you could brick up the window and fill the well and call it good.
Larry
Re: Caution if replacing window....
Lee Schierer
>I believe the secondary exit only applies if the basement is a live in space such as a bedroom. Shops, utility rooms etc may not have that requirement.
Lee
