Handheld Power Planer
Jerry Draper
>Thinking about buying a handheld power planer to edge joint long,6/4 thick boards for a table top. Can accurate, square edges be achieved with this tool? What tool features should I consider?
Re: Handheld Power Planer
>Why do you feel you need a power planer? What's wrong with going from table saw to hand plane to glue up?
I have a Craftsman that I inherited from my stepfather. It works fine, but the only thing I've really used it on has been door sides and bottoms.
>A power planer is not a great choice for that application. If you cannot get a decent glue joint from your table saw then another option is using a router. Use a straight bit with a bearing guide and a straight edge guide and you'll get acceptable results.
Tom
>Good Morning Jerry,
I agree with JL. I would not hesitate to run 6/4 through my tablesaw. With a sharp blade and featherboard, you may even be ready to glue up directly without even a hand plane. Try it.
George
Agree with JL
Neal in San Jose
>I have a Makita power planer, and it makes short work of taking off large amounts of stock, but it is nearly impossible to get glue-line quality edges. A hand plane in the 7 range is much more accurate, and the learning curve is surprisingly quick.
Kneale Brownson Dreaming of the Snow in N. MI
>I'd look for a different option for preparing tabletop glue-ups. If you can't get a jointer, try the hand plane or Thomas's router idea or a really fine cutting rip blade for the tablesaw.
Like JL, I have a Makita hand-held planer I bought to trim door ends when I had lots of rentals and needed to replace doors occasionally. I wouldn't want to rely on it to joint tabletop boards.
Thanks to all.
Jerry Draper
>Good advise. Glad I asked before buying. I'll stick with my BU jointer.
Not so fast, Here is one
Keith Newton, LR, Arkansas------WebKitFormBoundary
>I have had one of these for around 25 years, and it does a great job as any jointer.
http://www.tylertool.com/mak18634powp.html
The smaller powerplanes don't come close to being as good as the ones in this size.
