Door will not shut
Door will not shut
Door will not shut
Chuck Kettler Greenwood IN
>We had some rain here in Indiana. A lot of the rain blew against my kitchen door. It is a steel door with a 70% glass insert. The door frame has apparently swollen at some point and now the lock and latch are not lined up with the morises. So, the door will not shut. Should I wait for the frame to dry and hopefully it will close and lock or should I move the strike plates and be done with it?
Re: Door will not shut
Wait
>Or use a bigger hammer |;-}}}}}}
Mo . . just wait, really. What was will be once again.
John McGaw
>Not to be alarmist but the problem _could_ be something more than simple wood swelling. In fact it is hard to imagine what sort of swelling in the frame or door would cause a great deal of movement with the grain orientation normally used. Something to think about is a shift in the structure of the building precipitated by excess ground moisture. It doesn't take much of an offset in the footers (or slab) to throw all sorts of thing out of alignment. It is definitely something to keep an eye on.
Agree with John on this
>Swelling jambs wouldn't move the positions of the strike mortises. I suspect something else has settled. Or, possibly your sills have absorbed moisture differentially and one side of the door frame is now higher than the other. I'd check the frame to see if it is still square at the top and if there is now an uneven gap anywhere.
Ellis Walentine, Host
Pete in Holland, MI
>Does the door appear too wide for the opening, or is it dragging top or bottom, indicating the opening is out of square ? The opening too narrow would indicate swelling. Out of square potentially structural in nature.
I'll wait and do some measurements
>The possibility of a slight shift of structure exists. The door does still fit in the opening, it just does not close sufficiently to latch. If the rising water would have come up another foot I would have had a basement and shop full of water. So, after the worst flash flooding in Indiana history do I pop for flood insurance or play the odds? Thanks for the feedback, I'll post what happens when it does.
Re: I'll wait and do some measurements
>Chuck, I don't know how old your house is, but there is another aspect to this. If you have a Builder Warranty or some such thing (less than ten years old) then a door that can not latch or will not open might be an indication of a structural problem caused by the flooding and the insurance might kick in. If you fix the door, the clue to the problem "goes away" and the insurance company will ignore you. Locally we had people that had claims and lost them for this reason.
