Better Than Advertised ! (Long)
Dave Anderson (PacNW)
>I have just finished testing a brand of brad point bits from Woodcraft that far exceeded my expectation. They are the "Colt TwinLand" brad point bits. They come in 1/4 inch to 1 inch. What sets them apart from is the unique double land design. Behind the first land on the flute, there is a second land along the backside of the flute. They advertise as being having improved accuracy and Zero chip burn. I bored a series of holes into 3 Inch hard maple and red oak. I used 1000 rpm with the 5/8 and 3/4 bits and and the feed rate was as fast as the chips would clear. The chips were ejected non stop and did not require any backing out to clear. The 3/4 holes in the maple were almost glass smooth. When I measured the (6) 3/4 holes with a dial caliper, they all measured .750 on both ends of the hole. I had the same results with th 5/8 bit. All exit holes are chip free and there was no burnig in the maple.
Nice to be surprized,
Dave Anderson (pacNW)
Re: Better Than Advertised ! (Long)
Don in Northern Arizona
>Dave,
Did you test the regular Twinlands or the pricy HSS Five Star Twinlands?
Don
Regular Twinand's
Scott Greaves in Blackfoot Idaho
>Very Interesting!
Are they only available from Woodcraft? Do they only come in sets, or are individual bits available?
Thanks for the heads-up!
Scott.
