Looking For A Hinge, Pic
Re: Looking For A Hinge, Pic
#2Fabricate it yourself?
Charles R. Smith
>Jim, I hope that someone on this forum can provide you with a source for one. I looked, but couldn't locate anything of that ilk. Failing the ascertainment of a commercial resource, I would think that it would be a rather simple task to fabricate one yourself. The challenge might be what form the central pin would take. Good luck!
Charles
Closest I could find.. *LINK*
Jason Roehl in Lafayette, IN
>...but it's not the same finish, and it's backwards (perhaps it could be disassembled and flipped?).
Jason
Pivot Hinge
#4Re: Looking For A Hinge, Pic
Ed Mulligan, Cape Cod
>Jim -
If you don't need the exact appearance in your photo, any hinge with the pivot in the same relative position would work. Look at overlay hinges and offset hinges for possibilities. Good luck!
Ed
Re: Looking For A Hinge, Pic *LINK*
Lee Gordon
>It looks a little like a pin & pintel type hinge that's used for hanging some exterior shutters. Maybe a supplier of shutter hardware would be a good place to look.
http://www.customshuttercompany.com/hardware_ext_pintels.shtml
#6What is it?
Lee Schierer - McKean, PA
>I've seen similar hinges, but can't recall where. What is the item in the photo? Maybe that will jog my brain.
Lee
#7Pivot Hinge
>Used to give 180+� swing to a door and a table's fold-out extension leg. Variation is in kitchen doors that swing both ways and the hinge used a cam block to self-center the door.
