RequestHow to best bevel rip pieces at 22.5 degree
North of the Border
>My tablesaw doesn't have good bevel gauge setting (I can only trust the blade at 90 and 45 with my tri-square). Does anyone have any good suggestion on how best to bevel rip pieces at 22.5 degree accurately. I'm going to bevel rip eight pieces, each 1/4" thick x 5 9/16" x 1 1/8" at 22.5 degrees for the sides on so a hexagon hollow column can be formed by gluing the 8 pieces together. Thanks for any suggestion. Is there a router bit that bevel cut at 22.5 degrees?
Re: RequestHow to best bevel rip pieces at 22.5 degree
Re: RequestHow to best bevel rip pieces at 22.5 de *LINK*
John Ballance
>You could construct a set-up block for 22.5 degrees, then use it to set your table saw. Using a 3 1/2" square piece of plywood, cut a diagonal from exactly the upper right corner to a mark 1 7/16" in from the right on the bottom (to be perfectly precise, the mark should be at 1 14.39/32"). This will remove a small right triangle from the right side of the plywood. The remaining block will have a 22.5 degree angle on it. Orienting the block upright, with the smaller "bottom" edge on the surface of the table saw, tilt the blade until it matches the angle you just cut.
Alternatively, Rockler carries a router bit 24798 for $38.99 that will cut your edge. The cutting edge is 1" long.
Rockler 22.5 degree chamfer router bit
Larry Marker
>A router bit is by far my choice. I've made a number of items requiring a bevel rip and I have always had better luck with the router. Any small deflection in the saw blade translates into a poor fit in the long joint.
Your pieces are rather short -- if possible, I'd rip and bevel a few longer pieces and then cross cut them to length. If you make them long enough, you can have a couple spares which will let you be picky to match grain/color and pick the ones that give you the most perfect fit.
Larry
Thanks to John and Larry
North of the Border
>I'll use both of your suggestions: cut a set-up block and rip a longer piece. I agree it's more reliable to use a router bit but this one-time job doesn't justify buying a new router bit for the time being. Thanks.
Roy Anderson
>I suggest a birds mouth bit in your router. It's intended for just this purpose. See link.
http://www.woodmagazine.com/woodworking-plans/rout
John McGaw
>I'd say forget the saw or use it only to rip to the approximate angle and then use a router bit to get the angle dead-on. Personally, for making hexagons or octagons I use bird's-mouth bits of the sort sold by Lee Valley since it makes the glueup so much easier but a regular bevel bit will do the job.
In The Mouth Of The Bird
