Need random orbital sander
Roy Anderson
>I'm a Neanderthal by nature, but I have some home repairs to do and I don't want to do them by the old methods. I want to get it done and over with.
I have to refinish the oak treads on my stairway. We pulled up the old worn out carpet and found some nice red oak treads. Unfortunately, there are some splinters, some nail holes and some stains. I need to get it smoothed over and refinished.
I think the best start is a ROS. Recommendations?
Re: Need random orbital sander
Sawman
>Porte Cable. I have been using them in my shop for years and they work great!
>Good Evening Roy,
I have the P+C, Ridgid, and DeWalt ROS in 5 inch models. They all c-an do the job. I prefer the Ridgid. However, you will need to get into corners, and ROS sanders have a frustrating time doing that. You may want to get yourself an orbital sander which can do it all. I like the Makita as well as the P+C Speedbloc quarter sheet models. The P+C #330 Speedblock would be my choice. The Makita will never, NEVER wear out.
George
North of the Border
>Sounds like you only the ROS for this job and don't really need it. If so, any ROS would do, the cheaper the better in your case. Wonder if the rent tools section at HD or Lowe's may give you a better deal. Why do you need a ROS if it's a floor to be covered by a carpet? If you have a belt sander, that might do a faster job. Follow it with a block sanding should be ok if the surface is to be covered.
Chuck in ND
>I vote for the The Porter-Cable 330 Speedblock also.
Roy Anderson
>I plan to only put a runner up the middle this time, leaving the ends exposed, so I need to get them smooth, stained and finished.
