Way OT - Breaking Up Concrete Sidewalk
howard
>Anybody tackle this?? Is this a "crazy" thing to do, or left to a bigger machine? I know there are pneumatic tools I can rent, or even a small backhoe. What say you?? Thanks
howard
Re: Way OT - Breaking Up Concrete Sidewalk
Jim DeLaney, Austintown, Ohio
>Lotta work, but doable.
Sidewalks - especially older ones - usually don't have any rebar or wire in them, so they break up fairly easily'
If at all possible, use a pry bar to raise one end/corner of the sidewalk section, and put a stone or brick under it to hold it up. Then, smack the center of the walk piece with a sledgehammer - the bigger, the better. I prefer a 16# hammer.
If you can't pry it up, it just makes breaking it a bit harder, but it WILL break.
For me, the hardest part is always picking up and hauling off the broken pieces. Back-breaking labor!
That said, I've got about 35 feet of walkway to tear up later this Summer. Worst part about this one is that a previous owner covered the concrete walk with brick, so I've gotta tear the brick off first, then smash up the concrete walk. Not looking forward to that...
Bill Howatt
>Don't really know about sidewalks but I thought I'd bust up a tilted concrete stair to make way for a new one. Sledgehammer just bounced off it after I got a few sharp corners knocked off. I ended up hiring a person with a backhoe, big jackhammer and truck. My neighbour tried to do his with a small jackhammer he rented. After about 4 days he built a wooden one over top of the old, now slightly rounded, step. However, I suspect a sidewalk may be easier though.
The other thing you have to think about is how are you getting rid of the old concrete. If you are going to load it into something then you might consider the backhoe to be a good move to cover both parts of the job.
I think I would go out and whack the sidewalk with a big sledgehammer. The results might give you an idea on how you want to proceed.
Bill
Fred Davis
>I have had laborers break up many slabs like Patio and sidewalks and it's not as hard as you might think
Like Jim said you need to pry up a corner and then stroke it with a 10 lb. sledge hammer or heavier if you have one .
The trick is the prying up.
Go down to your local tool rental and rent a "Johnson bar" . That is what they are called, it has a big strong wood handle attached to a steel L shaped foot and you stick the foot under the slab and pull back one the handle and Voila , up comes the slab with very little effort, then whack it a good one with the sledge and your on your way.
FredD
ROFL ! ! ! . . .
steve mackay
>Not at you . . . at me ! The last knuckle head to own this place had filled the 5' wide x 40' long "terrace" with concrete. Last summer it finally honked me off so I went to town with a sledge and buckets. Did four 5 gal buckets a day (or so). Took a couple weeks. No hurry. Thought about renting a power hammer but didn't want the area busted up while I took my time hauling it off. Before begining I was up to my 34" "fat-jeans". Afterwards I was back to my 33" cool jeans. Still have a patch beside the drive that ALMOST has me honked off. AND I'm back up to my 34s . . . where'd I hang that sledge ?
Re: ROFL ! ! ! . . .
William Falberg
>I cannot think of a more spiritually rewarding enterprise than to rent a jackhammer and tear up some concrete. It's serves to both re-assert your manhood and relieve the stresses that accumulate over time. Go for it. Your mind, body, spirit, and heart will thank you. Don't forget the prybar.
PS: It's even more exciting to do this wearing sandals and shorts.
Pipe and cribbing
Tom Dunlap
>I used a High-Lift jack to get one corner of each slab section up in the air. Once the slab is popped off the soil get it high enough to slip a 4" diameter pipe 4x4 or other cribbing under it. don't be stickin' your hands under the dead-fall trap. Setup a grid work about 10-12" apart and let the slap back down.
A few gentle whomps in the unsupported places will crumble things on both sides of the pipe or cribbing. almost the most effortless destruction you could ask for.
Tom
34" Inseam??!! . .
Jim Toews - Walla Walla, WA------WebKitFormBoundar
34" Inseam??!!
>Who'd of thunk that carting heavy buckets of busted up concrete could make your legs shrink a whole inch! I'm glad you've returned to your former height. ;-)
Cheers!
Jim
Phileas
>Back in the day, I'd recommend dispensing with the sledge hammer and using black powder to do your heavy lifting. A quarter pound in a duct-taped peanut butter jar placed dead center and set off with three feet of canon fuse ought to do it (after lowering that slab back down, of course).
In today's environment, you may get more attention than you really care to have. Still beats the heck out of the sledge hammer though, and it'd be WAY fun to "experiment!"
Phileas
Ralph Turney
>I was a concrete cutter for 17 years and broke up miles of sidewalk. First off, buy a sledge hammer (the heavier the better 16lb+...never use force, use a bigger hammer) and give the slab a good smack. A word about using a hammer and this is very important, make sure you hit the slab with the flat of the hammer face, if you don't hit it flat, you lose most of the force of the hammer. I'm 5'8 and 175 with no chest and I can ring the bell at the carnival all day long...it's the technique, not the muscles! I'm sorry to disagree with everyone here, but don't bother lifting the corner, that's just more work. With a simple hit of the hammer about a foot or so from the corner, you should break off pieces you can handle and not make a big mess with a bunch of little pieces that are hard to pick up.
Secondly, if it has ANY wire in it...hire a professional.
Good luck and learn to lift properly, once you mess your back up, it's over.
Thanks All...........................
howard
>My house is 47 years old, so I'll try a corner to first see if there is wire mesh. I do have a sledge, I need to check the weight. probably will do this in a few weeks so I will report back on how it went. Thanks again.
Nope . . .
steve mackay
>waist. Although my inseam IS 34 also. Can't do much about that one though.
LOL ! . . .
steve mackay
>Haveing used it before, before I started mine I looked around for some DET cord to cut the concrete. And, you right, stuff is not to be found out here for the common person. WOULD have been fun though. One of my skills SWMBO hasn't witnessed yet !
Re: Thanks All...........................
Ralph Turney
>Oh come on, just grab that big boy and go take a whack at it, it'll only take a minute. :-)
Re: Way OT - Breaking Up Concrete Sidewalk; THANX
wudwork
>Ralph, I read your post and decided some sidewalk needed removal. I am 46, decent health and program computers. I have a 10 lb sledge a pick and had a bad day at work. After using your excellent advise, I busted up 2 sidewalk panels. It went surprisingly well, your suggestion about hitting with face did the trick. That was yesterday. Today, I feel like a 2x4 is attached to my back. Although I might be well prepared for a carnival bell ring, I am calling in the guys that use backhoe or something besides my back. This is not fun stuff.
I do appreciate you tip, the technique you suggested worked great!
Tom
