ADVERTISE HERE - FREE TRIAL
OT: - Need to replace my 15yo Garage door opener
Bart Goldberg
Bart Goldberg
>Hi Everyone,
One on my two Sears, garage door openers appears to be near death. When you push the button to open the door, it buzzes for about 15 seconds and then just turns off. No movement in the gears from what I can tell.
Can anyone recommend a replacement for this opener?
Thanks
Bart
Re: OT: - Need to replace my 15yo Garage door opener
Paul Waddle
>Yep,go to the internet and look up garage door opener. Its fairly easy to just replace the motor/gear drive system,actually all you need is to replace the nylon worm gears-about 35$. It is quite a tedious task,and ifs hot,I'd soon have it done. Now if you break a spring,by all means,have a pro to do this replacement-125$ . Ive been down both roads. The only problem with you replacing the gears,will be adjusting the stops. pw
Ken Oakley-Sunny St. Cloud, Fla
>I just had both springs replaced last week. One broke but I replace both whenever it happens. Cost me $160. Unless I had a death wish I would never attempt to replace those springs.
>I have a Genie in this house. It works reasonably well. I had Overhead Door Company in the last house. They worked reasonably well - they looked a lot like the Genie, so they may have been relabeled.
Dennis Yoder
>Most openers are manufactured by the same company so its basicly price. that said I use Liftmaster from the Borg. Dennis Y
Tony - Memphis
>I have a LiftMaster too. Nothing fancy. After 9 years, I had to replace one gear. Nice thing about them is that you can buy parts all over the place. Replacing the gear was very easy and cheap. I try to remember to lube the gears now and then to prolong the next gear failure. That's the only issue I've had with mine. I'd buy another one to replace this one. I had a Sears at the old house (same unit) and hadm similar experience with it.
Tony
Dan Mitchell
>I've put several "big box store" Genies in 2 different houses over the years, no real trouble. I like the screw drive system.
Dan
Doesn't scare me nearly as much as my tablesaw ;-)
Dan Mitchell
>Ken - My last house had a '50's vintage double wooden garage door with 2 springs, very heavy door so very powerful springs. One broke & a "pro" replaced both. I watched the 2 steel rod tightening process & had the same reaction you did. Unfortunately, the guy didn't set the tension correctly & I had to adjust (tighten) the springs, by rotating the collars, using the "alternating rod" technique. I was pretty nervous when I went to release the set screws so the springs could be tightened, but it wasn't nearly as bad as it looks.
That un-guarded, howling dado blade, now THAT scares me! ;-)
Dan
Liftmaster - not from the Borg
Tim Greif - West of Chicago
>You may have gotten a Chamberlain from the borg, but not a Liftmaster. Chamberlain makes a bazillion door openers, including their own Chamberlain brand and Craftsman brand. But Liftmaster is their professionally installed line available only through independent door opener dealers. That said, there's not much difference is spare or replacement parts.
I have two 19 year old craftsman openers that I've replaced the drive gears on both and a capacitor on one.
Original poster's problem sounds like a bum capacitor. See the link below for parts.
Roy Anderson
>I vote for the Genie. I installed mine. There was no problem at all. They have great online support. Almost any issue, their web site covers it. I also vote for the screw drive over the chain drive, though I have had both with reasonable success. The screw drive is more shielded and less likely to snag something.
I also agree that you, a civilian, should never mess with the springs. I 've had springs break and you only need that once. They make a lot of noise and flail around when they let go. When mine broke, I had a company come out, you know, the one that says "We sell the best and service the rest". They did a great job. They had some tricky tools to set the springs just right and they tuned up the whole door.
It's amazing how much tightening up all the little hinge bolts will help the door raise smoother. They work loose over time and let the door rack. This is especially important if you have an older heavy door, like mine, circa stone age.
I Don't Use Or Own A Dado Blade.
>I much prefer a router bit in a plunge router. Now if you want to discuss howling, screaming things, take my wife---Puuleeze!
