Propane and Gas Engines OT
Dustmaker Mike
>Way back in the 70's I think it was my uncle had a truck that ran on propane as well as gas. I was looking for a conversion kit to maybe make mine do the same thing. The only kits I could find where for fleet vehicle's not sold to the public. I was also wondering if they would work off NG, then I could just have it plumbed off my house so the fill up would be easy and cheap. Any ideas on where to get these?
Re: Propane and Gas Engines OT
John Parker
>On the newer vehicles. You would probably need a chip upgrade for propane conversion.Propane has a slightly different flash point than gasoline. Propane is approxomately 15% less efficient than gasoline so you will burn about 15% more by liquid volume to go the same distance. Propane is pretty high right now so I do not think you would save much. Propane requires a tank that is safe under pressure. So the conversion is a little pricy. Natural gas is a good fuel but this conversion takes a pretty major modification to your engine. Natural gas can only be stored in bulk under high pressure. The pumping equipment and storage tanks are very expensive. Propane liquifies under about 300 PSI. Natural gas does not liquify under these pressures so to carry enough to be of any use the storage tank needs to be built like the oxygen tanks used for cutting torches.
Jason Roehl in Lafayette, IN
>You can get a compressor and the appropriate fittings to fill tanks with compressed natural gas (CNG) from your own house natural gas supply, but it would be very pricey--it would take a very long time to realize a savings. Not to mention the necessary modifications to the vehicle.
Jason
Larry Clinton At Frankfort (Central)., Indiana
>I worked for a propane company many years ago. At that time they had one conversion kit that just replaced the air breather on a Ford Pickup truck. To use it the engine was started on gasoline, then a switch was flipped that shut off the gasoline via a solenoid valve and opened a second valve for the propane. The gas pedal operated a linkage to the propane as well as the normal gasoline functions. I don't know if these are still available. Obviously you would have to install a propane tank somewhere in the vehicle. All the remaining trucks were complete conversions at a factory. As has been stated you get less mileage from propane so the savings is not too great, and the engine does put out less horsepower - also road fuel tax is supposed to be paid on every gallon of fuel used. In Indiana with gas around $4.00 a gallon the state tax is near $.50 and fed tax is $.185 / gal. (Note that if you fill a tank in a vehicle at a propane company or gas station that provides propane, you WILL be charged the road tax.) NG is a very complex conversion as the fuel must be not only highly compressed but also cooled - and kept in a high pressure insulated tank. The older (non computer controlled carburetor style) normal engine will run fine on propane - may need to change the timing slightly to obtain top performance. I'm not sure the new computer controlled engines or any multi-point fuel injector engines could be easily converted. In the early 1960's we added a feed line and valve to many farm tractor engines by replacing a bolt in the intake manifold - when the farmer used them for a stationary job such as pumping irrigation water etc., the engine was started on gasoline, then the gas valve gradually shut off while the propane valve was opened. When the engine was running on pure propane the speed was adjusted by opening the propane valve. Some of these tractors ran for several days this way. The major advantage of propane in these applications (other than cost at the time) was that the engine did not carbon up at all and the oil stayed very clean.
Hard valve seats.
Basil
>You need to have an engine equipped with hard valve seats. In the 60's and 70's, Chevrolets came already equipped with the harder seats. Ford and others did not and running propane in them usually resulted in worn out heads and valves at around 40,000+ miles.
Before converting to propane one should do a little research on wheather the engine spec's will allow for it.
With all the newer engines requiring no-lead gas, you probable wouldn't have to worry about the harder valve seat question but it is something that should be checked on.
Basil
Well Thanks all I was just wondering
Dustmaker Mike
>I knew it would be that easy.
