How to re-seal hand truck tires...
Brint in Richmond
>...that have broken the seal at the rim? I saw a post on this topic recently, but can't find it by searching. Can someone point me there? TIA
Brint in Richmond
Re: How to re-seal hand truck tires...
Tony - Memphis
>Well, what I did was to wrap a web clamp around the circumference of the tire and that worked to "squash" the tire. That worked well enough to push the beads against the rim while I aired it up. It was actually a wheelbarrow tire. After that, I put that green stuff in the tire and it hasn't gone flat since (over a year now).
Tony
Larry Clinton At Frankfort (Central)., Indiana
>I don't know if it is still available, but when I worked in gas stations many years ago we used a sealer in a can with a "dauber". It kind of looked like rubber cement. I know I has some tubeless tires with slow leaks on my trailer and took them to a local gas station a couple years ago, they cleaned the rims with a wire brush and did have some type of sealant they applied. It worked very well as I never lost air again. You might check with an Auto parts store. Personally, I would take the tire / rim to a gas station for repair. Tire and muffler repair to me are not cost effective at home. The cost and labor to do it at home often exceeds the dollars spent at a garage. Several years ago I was cash poor, shopped around for a week, purchased a muffler at about 1/2 list, bought my pipes and clamps and spent a half day, laying on my back, replacing the muffler system on an old Oldsmobile Vista Cruiser. About a week later I hit high water on a highway at about 60 and tore the entire system off! As I was in a real bind to get it repaired, I took it to a Beck muffler shop. Turned out they put a new system on for about $25 LESS than I spent for parts - and guaranteed it for a year! I have never touched one again. Full size tire repair in this area run between $5 and $10 - removed, plugged, sealed, re-balanced and re-mounted. There isn't any way I will mess with them for that.
Lee Schierer - McKean, PA
>Yes, the web strap clamp works quite well. The Ratchet type are the easiest to use. Just be sure to stop putting in air once the beads grip the rim and the tire just starts to pressurize. In a pinch you can use a rope and a stick, but it doesn't work as well.
Lee
Rope and a screwdriver
Tim Greif - West of Chicago
>I just did one for my neighbor. Tie a loop of rope around the tire at the center of the tread, sorta snug. Put a screwdriver under the rope and then use it to twist the rope up a few times to squeeze the center of the tread down and force the tire bead out against the rim. shoot some air in the valve stem until it just seats. Then undo the rope twist and remove it before fully inflating the tire.
An old trick I learned working in a gas station - the faster you get the air it, the quicker and easier the bead seats. Removing the valve core helps if you're having trouble.
band clamp worked for me
Bill Tindall, E.TN
