steel building as workshop/garage
joseph
>Any of you have any experience with pre-fab steel buildings similar to the one pictured below?
Any non-obvious pros or cons?
I've never seen one closeup, but have noticed the ads for a while now.
Right now my shop is crammed into the corner of the basement, and I want more room. Option one is to build an insulated and heated shop. Option two is to build an uninsulated garage-sized building to store the stuff presently taking up precious basement room (i.e. 2 canoes, 2 kayaks, bikes, mower, gardening stuff, etc).
Realistically though, option two is the most doable.
Just looking at options right now.
Re: steel building as workshop/garage
Dick Coers
>I know of one guy that had one. He said that he basically ended up framing a building "inside the building" to get it cheaply insulated. He said he should have built a stick built and did not recommend the steel building to anyone. If you would decide to have foam sprayed on, it's expensive, and you need to cover the foam somehow. They make good storeage if you don't care about condensation or climate control.
joseph
>Thanks Dick,
It confirms what others have told me...insulation is a must to prevent sweating if the building is to be used for anything other than storage.
Check out Amish pre-built bldgs...
Brint in Richmond, VA
>I did, and ended up with this 14x28 that I really like. Of course, it's still smaller than what I REALLY wanted, but I couldn't squeeze an 18' wide bldg between my house and the neighbor's tree. Still, it only cost me half of what it would have cost to erect a stick-built on site. And this was all built to my custom specs -- didn't have to take a model from the lot. (I added all the siding, doors, window, trim and electrical after it was delivered, of course.)
Re: Check out Amish pre-built bldgs...
joseph
>I've looked at pre-built but they weren't Amish...not to many of those in Canada.
Humm, maybe the Mennonites have some :)
