Finishing advice (religious theme warning)
>I've been collaborating on a set of Stations of the Cross. I make the plaques, stain the sides and now I'm supposed to put the final finish on. Stephanie is doing the painting.
Obviously, she doesn't want too much yellowing in the top coat. The wood is poplar with a gel stain on the sides - the center is a poplar plywood. The paint is a modified oil paint - which dries reasonably fast (month or two, not years).
I was thinking of using an acrylic or possibly a water borne polyurethane. I could also use Krylon Matte finish. These won't be up except during Lent and Holy Week (at least that's the plan). The rest of the time, they will be stored away.
Re: Finishing advice (religious theme warning)
>Clear lacquer, acrylic, or poly out of a spray can is a no-brainer.
Clint
Sam Layton
>Jl,
I do not understand why you would feel a need to include "religious theme warning" in your post. If you had xxx rated pic's I would understand the warning...
Sam
Re: Finishing advice (religious theme warning) *LINK*
Steve Schoene
>I think you should use the varnishes designed specifically for varnishing oil paintings. The reason for this is that they are made to be removable in case conservation work is ever needed on the painting. One example would be from Golden Paints which offers several products for that purpose. I think it's particularly valuable that the products have detailed use and technical data. Other products may work just as well, but you won't find the technical data to ensure that's true.
Golden varnishes
Re: Didn't want to offend anyone.
>Sorry if I offended you.
Re: They even have a local dealer. Thanks.
Sean Troy
>I agree. If someone has a problem with your post, they have more problems with themselves they need to take care of.
I'm not sure I agree with the above advice
Michael Dresdner
>It's best to go over oils with oils, but they tend to amber both immediately and over time. Going over a slow drying oil with waterbased acrylic or polyurethane might cause some adhesion problems.
It is best to wait until the oil paint is in fact dry. You can speed it up by putting it in a drying room with slightly elevated temperature, say, 110 degrees, but with moisture added to prevent the wood from drying out excessively. At that point I would seal it with one coat of dewaxed blond shellac or SealCoat, then top it with waterbased polyurethane, lacquer or best of the lot, waterbased acrylic. For the most part, it is fairly easy to remove finishes above a shellac barrier. Another option, if your shellac is blond enough, is to simply use shellac as the finish. It does not yellow over time, so whatever color change you get initially is all you will get. If that passes muster, you are home free.
