Re: Finish on white oak planter
Michael Dresdner
>You have several good choices. Deck coating is fine, but will have to be rejuvenated regularly. Any exterior finish, either oil based or waterbased, is also fine and depending on which one and how many coats you apply, will last considerably longer. Your choices for exterior coatings, in order of least durable to most, are exterior wipe on or Teak oil, waterbased acrylic or polyurethane, and spar varnish or spar urethane. If the planter has end grain that will be sitting on a flat surface, preseal the bottom, and especially any end grain, with epoxy prior to finishing. That will help prevent water from wicking up into the wood from the ground and seeping behind the finish, which can cause it to delaminate.
