Hidden compartment
Neal in San Jose
>I've put hidden compartments into chests by adding a tall (3 or 4 inch) base molding around the bottom of the chest and making the front piece of molding the front of a drawer. Picture a chest on chest arrangement. The bottom of the chest obviously has to be raised to allow room for the drawer, and the ends of the front piece of molding must be carefully done so that when the drawer is closed, it isn't too visable. I've used mitered corners, but they tend to get a little ragged over time, and it and loses the effect, so I now extend the drawer front so it looks like the sides butt into the back of the drawer front. Relieve the bottom of the drawer front with a cut out so it looks like the chest is sitting on legs so you can get fingers under it.
You can also just add a false bottom sitting on cleats above the "real" bottom. Two problems with this are that the chest must be empty before you can get to the false bottom, and there needs to be a finger hole which can be obvious, or some other way to get the bottom out (think magnets!). Fine WoodWorking had an article on hidden compartments that had several clever ideas within the last 10 years or so, but I'm at work and can't go looking for the issue.
I was making a HUGE amoire when the FWW article came out. The article inspired me to put 6 hidden compartments into the amoire, and I probably lost money on the commission, but it was fun challenging the owner to find all of the compartments. She found 3 and I had to tell her about the other 3. I'm not sure she ever did tell her husband about them!
