Door jamb question
Door jamb question
Door jamb question
Spencer
>I'm replacing old doors in my house, jambs included. Taking my old jambs off today, I noticed 3 kerfs about 1/4" deep ripped lengthwise in all the jamb parts. I assume that they are there to relieve stress. Do they serve a real purpose? i.e. should I put some in my jambs before they get nailed to the jack studs tomorrow?
Re: Door jamb question
Spencer
>I should say that instead of purchasing them, I milled my new jambs out of poplar, so they didn't come with any longitudinal kerfs in them...
Bill Howatt
>If the wood is dry and straight I don't think they are necessary at all. I made some 7" or wider ones out of pine that wasn't totally dry and had some knots in it for a gazebo type structure. I did put kerfs in it since it was obvious I was going to have to pull it a bit with the nails. Worked just fine.
Bill
Spencer
>I'm wondering if they are a holdover from the days before air conditioning. I've never had much problem with kiln dried lumber staying put for shelfing and various other little tables that I've made. It seems like they were historically put there to help deal with the large humidity swings that existed before there were means to control humidity effectively. I'm rapidly arriving to the thought that to rip them would be busy work.
NickB in Needham Mass.
>I don't think they are necessary. I believe they are stress relief (on my almost done (3+ years now-only a few closet doors left) door replacement project, I ordered poplar jamb boards for the first tranche of doors (I ended up milling my own for the second tranche, because the lead time for the boards was so long, and I ended up with nicer, straighter jamb boards when I did it myself, although it did take a bit longer). From what I could tell, the jamb boards that I bought had been through a 4-sided planer which put 2 shallow grooves in the back side, which I assume was for stress relief). The ones I made did not, and they are fine (I did tend to mill and install the same day, though.
Hope this helps,
Nick
Spencer
>Thanks all. According to the hardwood flooring dealer from whom I purchased my floor, the only reason that pre-finished flooring manufacturers relieve the backs of the flooring pieces is to save weight and thus shipping cost. I wonder if the jamb makers relieve cut for the the same reason nowadays... Who knows.
I decided to mostly leave them alone. I did put relief cuts in a few pieces that had a little twist in them that was present when I milled them. I'll let you know in 20 years if I had a problem.
Fred Davis
>Your "hardwood flooring dealer" only connection to flooring is that he sells it.
FredD
