Veritas - Innovation in Tools
how to cut bowed plywood?
billfrommich
>A few days ago I purchased some plywood from Lowes (construction project material sanded on one side) that I will be using to make some ramps. The plywood is bowed with the center about 3" out from the ends. I planned to cut it up using my new circular saw and edge clamping style cutting guide, but the guide cannot be attached. Any hints for dealing with this situation? The only thing I can think of is to weight down the bowed wood with concrete blocks on either side of the cut.
Re: how to cut bowed plywood?
Steven Antonucci
With a bowsaw? :-)
steve antonucci
>Sorry, couldn't resist.
Lay it down flat for a couple of days with some weight on the top to see if it flattens.
Steven
Clamp or screw 2x4s to the convex side
Ed Mulligan, Cape Cod
billfrommich
>I'm hoping that there is some trick that avoids the need to physically straighten the plywood by clamping, weighting, etc. Is the warp produced by differential moisture gain/loss on the opposite sides? Would laying the sheets on the ground with the "wetter" side (the convex side?) up allow the sides to equalize, at least temporarily? Incidently, of the three sheets I have, two are convex on the sanded side, the other is convex on the unsanded side.
>I've not tried to straighten plywood the way you describe. It might work, and no harm done if it doesn't. Try it! I know the method works on solid wood but plywood is a very different material.
As for the cause of the bow, it might be one side is wetter than the other. It might be that one of the inner plies is at a different moisture content than the others, or was during the manufacturing process. Improper storage is another possible cause.
Ed
