My shop is finally coming along... *LINK*
Brian Gray in Sandusky, OH
>It's been a long and weary road the last couple of years in my endeavors to get my shop rolling, but it's finally happening.
The story shortened....
My wife and I moved to our new house almost two years ago. Fully intended on building the shop as soon as we free up cash from the old house.
Two mortgages went on for more than a year (!!!!)
Job crisis (!!!!)- four months later job crisis solved.
Sold the house and solved the job crisis around the same time.
Started shop project in October/November of '07.
Concrete guy drug his feet, missed his weather window, and didn't get footers dug and set until this spring (!!!!)
So now the entire exterior is complete, except for a staircase that I will build on the back exterior wall.
Now it's electricity, insulation, and drywall.
So about a another month, and I should be set.
Shop
Re: My shop is finally coming along... *LINK*
Technical remarks
Rod Peterson -- Ormond Beach
>Nice shop—blah, blah, blah…
I really like the spiral bind left edge of the photos column. I stole the image and looked at the source to see what they did. I sort of had an idea, and in general terms I was right. It was just done a little differently than how I might implement it in a future application.
Please contact me for inclusion in ShopTours.org, especially when you get some tools in there, although we don't have enough genesis tours on the site.
Rod
Fred Davis
>Well done, looks like a Carpenter was involved in there somewhere ;-))
FredD
A question about the trusses
Henry Higginbotham
>You mention that the usable width in the attic went from 8 feet to 13 feet. Do you have any pictures or drawings of the revised trusses? The roof pitch doesn't appear to have changed (I can't read the drawing, but it looks like an 8/12). Did changing to a wider attic adversely affect the load capacity of the attic floor?
I ask because the trusses look identical to mine in your original plan. My width is 8 feet, and I'm always wishing it were more, although I wouldn't want to compromise the strength. Too late now, anyhow.
And a suggestion: Put in all the electrical receptacles you can scrounge up--you'll be glad you did.
Here's a pic of the trusses....
Brian in Sandusky, OH
>This should answer your question....
Re: Here's a pic of the trusses....
Henry Higginbotham
>Thanks, Brian. Looks like they just moved the queen posts out and gussied up the top and bottom chords (2x8s?). Did the truss company say what kind of load the attic would be rated for?
I had them modify mine to use 2x8 bottoms, but left 2x4s elsewhere and the standard 8-foot width. As I recall, they gave the rated load as 80 pounds per linear foot, per truss, along the 8-foot width. I'd have preferred to also have the maximum concentrated load in the center, but they said they didn't have anything on that.
>I didn't get any data on the load limit, and I probably won't worry about it.
The attic will be half office, and half attic space, so there won't be any significant load.
Thanks.
Larry Clinton At Frankfort (Central)., Indiana
>Real sharp looking shop Brian, something to be real proud of having. I'm sure you will have many hours of happiness inside. What type of heating/air conditioning are you installing?
>Propane furnace with an air conditioner.
Re: Thanks Brian.
>I installed the same type system in my shop except I have Natural gas instead of propane. As I installed HVAC on the side for about 25 years, I designed and installed my own. I put a direct vent furnace in the upstairs room, dropped the Hot air trunk between the trusses (do have about a 4" drop in the shop ceiling drywall covered), I built a plywood box for the return air beside the furnace and draw my return air through it with a filter grill in the shop ceiling. Although this requires a stepladder to change it only requires changing about once a month due to the ceiling location. I ran the primary trunk to about a foot from each outer wall. Then installed secondary trunk running at right angles that run about 25' each. My registers are about a foot from each outer wall. I don't have any cold spots in winter (even by the 8' X 9' garage door). I filled over the pipes and trunk with blow in insulation & super-insulated the entire shop. I have a 30' X 30' shop with 10' ceiling and a 10' X 30' upstairs room with 8' (kneewall) ceiling. I estimate (can't be exact as my home and shop are on the same meters) my heat bills as less than $100 during the coldest month and about $20 in AC in the hottest month. That's keeping the shop between 65 ~ 75 in winter and at 70 ~ 75 in summer. Even though I'm not in the shop I keep the temperature there to protect the equipment from condensation. I sure hope you "super-insulated" your shop as I know propane is quite a bit higher than NG.
Spencer
>Forget about the shop, your pens are awesome! I'll send you an email...
Joe in a Cleveland Suburb
>Wow Brian. That sure looks nice.
Some day when I'm visiting my folks over at Catawba Island, we should meet up!
Joe
Definitely, Joe...
>Send me an email anytime.
However I live in Milan...little town south of Sandusky.
I just never bothered to change my username when we moved.
