Air Lines
Air Lines
Air Lines
Sawman
>I am going to install hard air lines in my shop. I have decided to go copper or iron pipe. If copper what type would you go with?
Re: Air Lines
Jason Roehl in Lafayette, IN
Re: Air Lines
>K or L. K is thicker and more expensive, but will last much longer, but L is plenty thick and will probably fit the bill just fine. I wouldn't even consider type M.
Jason
Re: Air Lines
1/2" "L"
Re: Air Lines
Re: Air Lines
Larry Clinton At Frankfort (Central)., Indiana
>3/4 black iron pipe is about 1/2 the price of the cheapest copper line. If you have a threader and cutter (can saw with either saber or sawsall if reasonable careful to keep straight cut). You can check out the specs for copper line pressures etc using Goggle. I believe any of the copper tubing (types K, L or M) would satisfy your requirements and last 50 years or more. If you have fairly long runs, I would use 3/4" as the main line and drop with at least 1/2". Brazed type fittings are by far the cheapest if using copper (and have the least restrictions - carry more air for a given size) - If you have the experience to braze.
couple of reference pages you may want to look at.
http://www.copper.org/applications/plumbing/techref/cth/tables/cth_table1.html
http://www.copper.org/Applications/plumbing/techref/cth/tables/cth_table3c.html
As a retired Engineer and once Indiana State licensed contractor plumber, I would recommend you use Black pipe. If you don't have the threading equipment - you could rent it for a day or two and still save money on the total job. The black pipe is just about indestructible, stays straight, quite easy to hang near the ceiling (requires very few holding straps due to its rigidity) - I would also recommend you run all drops up from the main - then back down. This prevents any water from entering the drop. The main line should be installed so it slants back toward the compressor and / or a drop at the end of the line with a shutoff be used to occasionally drain the line.
Re: Air Lines
Re: Air Lines
>Conventional wisdom usually suggests 3/4" line. As a practical matter, unless the run is more than several hundred feet and/or you're operating multiple tools simultaneously, any pressure drop at the tool will be imperceptable with a 1/2" line. I run 1/2" Type L copper about 40 feet, with a drop every 10 feet. At the end of the line I run 75 feet of hose for outside work. Yesterday, I sand blasted an old iron gate with the regulator pressure at the head of the line set to 120psi. I didn't measure it at the gun, but if there was a couple psi drop, it didn't show.
As far as cost is concerned, for the small shop system the difference between iron and copper is a few bucks at most. And working and sweating copper is pretty easy. Plus, it doesn't rust.
Suggestions:
*Interface the compressor and the line with a braided connector to isolate vibration.
*Install drops up and down to keep water out of the tool.
*Incline the line an inch or so from the head to the end, and install a drain at the end.
*A regulator with built in oil/water separator is a good idea if high humidity is common.
End-of-line drop
Re: Air Lines
Braided connector
Re: Air Lines
nice idea, but a question
Tim Greif - West of Chicago
>I like your end of line configuration and I also have a short whip (although mine's rubber) connecting the lines to the tank. But I don't see a union in that flexible arrangement. How do you disconnect the tank from the line without one?
Re: Air Lines
Re: nice idea, but a question
>It's a 5hp two stage 80gal IR compressor, bolted to the pallet it came on, over a horse stall mat, permanently wired. It ain't gonna move during my lifetime. If something would happen requiring a disconnect, I would just cut the copper. It's easy enough to sweat a new union.
Clint
Re: Air Lines
One Answer
>I had my jumpers (hi pressure [250psi] 3/8" Speedair rubber hose) made at a local shop. For the main tank to the copper I had the guy use a union-type fitting on one end that mates to the other half sweated on the pipe-end. Simple on and off.
mm
Re: Air Lines
Understood
>Mine's a horizontal on wheels that gets moved every so often, so I need the union. I also like Mark's idea of swivel/union type of fitting on one end. That's done on hydraulic lines all the time.
Good advice all around guys. Have a good weekend.
Re: Air Lines
Re: Air Lines *LINK*
Alan in Little Washington (NC)
>As far as handling air pressure, Type M (thinnest of the three) is more way than adequate- it is rated for over 400 psi internal working pressure for 1/2" annealed (soft. Type M is not usually available annealed) and over 900 psi for drawn (hard)!! Check out the pressure ratings on pp 26 in the Cooper Tube Handbook. If you run your lines where something might puncture them, then heavier gage might be appropriate, however since the will only leak and not shatter, and at the price of copper today, I'd chose Type M!!!
Copper Tube Handbook
Re: Air Lines
Re: Your correct Allan
>But if you braze the fittings (not solder) as recommended for high pressure, the heat from the brazing process does "anneal" the portion of the tubing near the fitting. Again, the pressure rating is still more than adequate for compressed air as the (bottom rating as I recall) for 3/4" is still above 300 psi WORKING (not burst). I think the highest rated compressor I have ever seen was well under that pressure.
