Cutting Board Inlay
Cutting Board Inlay
Cutting Board Inlay
Jeff H.
>I am seeking information on the practicality of using inlays on cutting boards. Would love it if you would share your dos and don'ts. If any of the inlay woods would need to be dyed, can you recommend the wood and the dye.
Re: Cutting Board Inlay
DizD
>No experience with inlay. If you're producing a "user" board, I have had good success with laser engraving for decorative accents. Also considering a board using a row or two of end grain strips as accent pieces.
Ed Mulligan, Cape Cod
>I haven't done this so this is just an opinion. Inlay is usually 1/16" to 1/8" deep. The cutting boards I've used wear down by this amount in a few years so durability of the inlaid design is an important issue. I would make 'inlays' that are the full depth / thickness of the board.
You can make a full depth inlay as follows. Make the board, then cut it apart with a band saw, sandwich a contrasting wood in the cut, and glue back together. After the glue cures, repeat until the design is complete.
You don't mention whether the cutting board will have end grain or face grain on the cutting surface. If it's end grain, you can make your cuts in any direction. If it's face grain, cuts across the grain will be weak.
For color, I would use natural wood, no dyes.
Ed
wudwork
>Consider laminating strips together, like most people do. Then take another piece of wood, same size and thickness, and stack them like 2 piece of bread together. Now run the scroll or band saw thru along the direction of grain. Instead of bandsawing straight, zig zag around. When you are done, the 2nd piece of wood should just drop down in the opening of your laminated strip board. Now glue that up.
A little confusing to describe, but you get the idea ?
HTH, Tom
