Re: OT Cultured Stone
Grant in Iowa
>$20 per square foot seems a bit high. One of the following would explain it:
-Your GC is marking up the masons work significantly
-The materials are expensive, consider different materials such as brick
-Your GC is marking up the work significantly
Consider how much the materials that you chose cost and add in additional time for the mason to come apply chicken wire and a scratch coat. Then consider how complex the work is (columns, arches, goofy designs) and decide how steep the price really is. It may just be the going rate for that work in your area.
The other possibility is that the GC is marking up the work significantly....
Regards,
Grant in Iowa
