Trowel-on filler under veneer?
pecker
>Ordinarily I veneer flat panels in a vacuum press, then saw up the panels into the required parts for a project. This time I needed to build the assembly first and try to veneer it afterward. Unfortunately due to a slight misalignment and some cupping of a piece of plywood, I have a broad area, about 6" x 36" that is not flat with it's adjacent panels.
So...I need to be able to apply a filler, about 1/32" thick to this area and sand it smooth before putting it in the press. Drywall compound would work great for this, but I don't know if the Titebond cold press veneer glue will adhere to it. Can anybody recommend the appropriate product to use for this filled in area, for this application?
Thanks.
