Why you should not let things sit around
Thomas S Stockton
>Hi all
I'm working on a pair of eliptical nightstands that have a starburst or pie veneer pattern on the top. I cut, joined and taped together the veneer while I was doing all the veneer work for the job. The pies sat sandwiched between ply for a week and a half during which time the weather changed from hot to cool and wet for 5 days. When I went to press them up this is what I found, about a 3/32" gap in the center. Bummer, I took them apart and retaped them back into half sections and redid the joint. Took about an hour. I roughly figured that the wide end expanded about 1/170" of an inch to cause the gap not a lot of movement but enough to cause problems.
Tom
