My Tabouret Table, A Project Review
Jim Shaver - Oakville, Ont
>Hi,
It�s been awhile since I posted some work, I recently finished a small project and thought I�d post it here.
A few months ago I took a hand sawing class with Chris Schwarz at a Woodcraft in Michigan. That class inspired me to go home and pick up my hand saws and make a project that involved these newly leant techniques. I wanted to blend these saw skills with some of the basics I had already been using with my other hand tools and complete a useful exercise-project.
As luck would have it Chris influenced me again, I had a copy of Woodworking Magazine with a small Tabouret table on the cover. I read the article inside and decided I would use this table design as my exercise-project to test out my new saw skills.
If you know Chris, you will know that no simple project or project that he writes about is simply about the plan, his writings incorporate interesting histories or technique elements and explanations that take his words from a level of instruction to a journey.
After reading the article I decided that I would also use this exercise to test out a Jeff Jewitt glazing technique I have been lingering over now for some time.
The new techniques for me in this project would be mortice and tenon joinery all by hand, dove tailed cross members and half lapped stretchers and corbels.
Hand cutting also all my rough lumber by hand, controlling my cuts to layout lines . The only power actually used was in ripping the rough stock and jointing and planning the stock to shape. I also did cut the table top on the band saw and made a leg detail on the feet that Darrell Peart explain in detail in his book �Greene and Greene furniture�.
I chose some quarter sawn white oak to make this table. The wood for the project came out of two boards, an 8/4 board provided the legs and a 5/4 board provided the table top and stretchers and corbels.
I followed much of the plan from Chris�s article with an exception, I added a foot detail I have made before using a simple jig and a straight cutter with a router. The details for making the jig and cutting the profile are well documented in Darrell Peart�s book
As mentioned the glazed Mission finish is one posted on Jeff Jewitt�s web site. The following were the steps I followed
Stain with TransTint Brown Mahogany diluted at 1 oz dye to 2 qt.* water
Apply one coat General Finishes SealACell Sealer.
Let dry one day and scuff sand with 320 grit
Apply Bartley Walnut Gel Stain. Wipe clean and let dry overnight.
Apply 2 coats General Finishes ArmRSeal Satin Finish.
Apply furniture wax and buff.
Here it is.
I like the look, it�s a bit dark for my liking but it was a good exercise project that I was able to apply some of my newly learnt sawing skills to and also to develop a finish that I can improve on but like just the same.
A fun little project that taught me a lot, working with hand saws now has become a part of my process. Thanks Chris!
Thanks,
Jim
