Air compressor follow up
Sawman
>I notice that some units have a lubrication component?
Sawman
Forget'em
>The lubricators, or the FRL [filter-regulate-lubricate] units are used on lines that run air tools requiring lubrication. The problem is that once you introduce oil into the system, it's contaminated with the oil and cannot be used for things like spray finishing because the oil molecules in the pipes and hoses will fish-eye most any finish. If you plan on using an air tool that needs oil, simply add a few drops of oil to the tool for every few hours of planned use.
Re: Air compressor follow up
Don Evans
>As stated air tools need lub (oil). I agree, don't get an inline lubricator for your shop, they are ok for factory applications and assembly line workers who do only one thing with the line. In our shops we normally want a line set up for multi purpose so you don't want oil in it.
Also on filters, remember that the smaller the bowl on the filter unit the better job it will do in removing moisture. A small 1 ounce bowl is best for end of the line installation. Also pay close attention the the pressure rating on them, most if not all see through (plastic) bowls are only rated for 125psi.
My compressor is 175 psi so I had to install a regulator at the tank and I step down to 100 psi, then it feeds a distribution panel with multiple lines with a small filter and regulator on end of each line.
Don
PS
>A note on "see through" and plastic filter bowls.
If you are kind to your compressor by using synthetic compressor oil, you cannot use Lexan (Polycarbinate) filter/separator bowls because the the air flow with pick up compounds in the lub that will attack and dissolve the plastic. Use synthetic oil, but go with metal filter housings and bowls. The attached photo is an example.
Larry Clinton At Frankfort (Central)., Indiana
>I have a FLR (Filter, regulator, lubricator) unit at my tank (it was free from some scrapped machinery at the plant I retired from) - but i do not use the lubricator. I add 2 or three drops of lube directly to the air connection of my air tools before each use. As Mark said, the oil may contaminate some spray finishes (depends on the oil used and the finish being sprayed). The only time I would add one would be at the end of a drop dedicated to a particular air tool which requires lube.
Re: PS
Don Evans
>Here's a challenge for you Mark. Find me a filter with 1 oz. capacity that has a metal cover! I've never seen one. I have a filter on the output of my tank about the same size as the one you show and it NEVER removes any moisture but the small ones at the end of the lines do. I should clarify that not all filters work the same. But all the small ones I've seen use a swirling motion inside the bowl to sling the water out of the air, smaller the bowl faster the air swirls and therefore more moisture removal. Large bowl, slow air swirl less removal. They work just like the spin cycle on a washing machine except the air is spinning not the filter assemble, be cool if it could. It's not the fiber material inside that removes moisture, it is there for larger object removal, dirt, rust particles etc.
Don
Me & Mr. Boyle
>Sorry to kick this into "law" but can't help it. My main moisture remover is my air receiver since that is first up on Boyle's Menu on condensing mechanisms. The head pressure on my compressor is 200psi, therefore, with my receiver set to a max of 145, Boyle tells me I'll have some meaningful expansion of the air and resultant cooling of the vapor in the receiver. [Duh, Mark, everybody gets water in their tank!] True, but how many tanks are kept drained like they should be? [Not enough] Right. That's why I have a pressure-actuated auto drain installed to keep my tank (and the air inside) as dry as I can. I then run my lines in copper and everything is branched off a drop & loop set up to further condense as much vapor as possible. My lines are dry, i.e. I drain perhaps a 1/4 teaspoon of condensate from the drops per year. Those large can filters give me another expansion event and the chance to condense a bit more with the cooling effect, but I get at most a few drops out of the filters' drains. Does that mean the filter cans don't work or that my air is dry by the time it gets to them? Toss a coin.
I don't need hyper dry air for what I do. If I did, I'd put a powered drier in the system.
Make no mistake, I'm not saying my system is the best, but it's one solution that has worked quite well for me for over 6 years.
peace
mm
