Air compressor filter
Sawman
>I have a 5 hp 30 gallon Sears compressor. I am thinking about running pipe around the shop with a few drops to have air available. So do I need a fliter at each drop? Or just one by the compressor?
Sawman
Re: Air compressor filter
Larry Clinton At Frankfort (Central)., Indiana
>Sawman, it depends on a couple of things, first what kind of piping you will have - and what you will use the air for. For example, all air lines will have some condensate in the pipes. If you use iron pipe, you will have some rust eventually come out of your drops. If you are using the air to spray finish, you definitely want a filter at the end of the drop, just before the flex line. I would also want one if the drop is supplying air you will use to blow dust off a project, a blast of rusty moisture may turn the oak in a real great project black. You will need regulators at the drops to set the pressure depending on what you are using, Air brad nailers, etc may need a lower pressure than say an impact wrench or sander. By the way if you have a salvage (junk) yard near you that picks up at industrial factories, you may find all the filters. lubricators and regulators for next to nothing. Most factories, when scrapping equipment, leave all those on the equipment and 99% of the time they are as good as new.
Tom MacGregor
>All piston type air compressors heat the air as it's compressed. Moisture in the air condenses back out as the air expands and cools. Although they also pass small amounts of oil, sludge and contaminents, it is this moisture that is the biggest problem and you actually want to seperate it out, not filter it. Placing the moisture seperator too close to the tank allows water vapor to pass through and condense in the air line. Place a water seperator well downstream from the tank or at the point of use. If you will be using the air for a critical application add filtration after the seperator.
