Trim Router
Scott Greaves in Blackfoot Idaho
>I know, I'm sure this is in the archives, but just in case there is something new I should consider, I thought I'd ask it here.
I finally find myself in the market for a nice trim router. I have two uses coming up, the first being a countertop that I want to cut a chamfer or bevel around the edge. Second, we will be applying trim in our cabin in a few weeks, and we have chosen to go with 1x4 pine boards for all trim. It's a cabin!!! The only place this is any kind of problem is around the doors (casing). Where we're using a square profile board rather than one that tapers down towards the door opening, I will need to cut a recess at the hinges.
So please give me your recommendations for a good, reasonably priced trim router!
And if anybody has ever cut recesses for hinges as I described above, I would love to hear your take on the process, and what kind of bit you might recommend. Last Fall we trimmed out one room, and I ended up cutting these recesses by hand with a chisel.
Thanks!
Scott.
