ADVERTISE HERE - FREE TRIAL
Wixey Degree Angle Guage--Left Tilt Saw
>Good Afternoon friends,
I buddy of mine acvquired the Wixey which was talked about a few days ago here with positive opinions. I had the
opportunity to use my friend's guage this morning and discovered that when used on a left tilt blade, its readings must be subtracted from 90 degrees to yield the correct tilt angle. The Wixey seems calibrated for right tilt arbor saws, so its angle readout can be made directly from the dial on a Wixey placed on a right tilted blade.
It is cumbersome to have to convert readings to my saw, even though I learned to subtract years ago. Is there any device on the market which is or can be calibrated for left tilt saws?
George
Re: Wixey Degree Angle Guage--Left Tilt Saw
Look at it theis way
Forrest Addy
>Plant the angle thingy so it faces away from you. It's a PITA but your thingy will read directly. Mount small mirror so you can read the display (backwards) from where you crank the tilt.
I have one and this deficiency needs to be addressed by Wixey
Eric Murphy
>I don't have one and I haven't used one but I was just looking at the Beall Tool Company's website at the Beall Tilt Box (http://www.bealltool.com/products/measuring/tiltbox.php). The photo shows it stuck to the blade on a left tilt saw and reading correctly. There is also a video of it in action at http://www.newwoodworker.com/reviews/bealltiltboxrvu.html. In the video, it is also stuck on the blade of a left tilt saw and it is shown reading correctly.
Thanks for raising this issue as I was planning to ask for the Wixey for Father's Day. This may be enough to lean (no pun intended!) me towards the Beall instead.
Eric Murphy
>I just noticed that Lee Valley sells the Beall Tilt Box. The Lee Valley page says that it has a range of 90 degrees to the left or right and it has magnets on both sides so I am left to assume that it will read 0 - 90 on both left tilt and right tilt saws.
Lee Schierer - McKean, PA
>George, according to the Wixey site it is supposed to read +/- 180 degrees, so it should read either way. Try putting it on the other side of the saw blade so the readout still faces you.
Or, once you establish that the blade is at a true 90 to the table according tothe gauge. Place the gauge on the blade and re zero it so it reads zero when it is on the blade. It should then read correctly as you tilt your saw.
Lee
P.S. I have one of these on my most wanted list.
Tilt Box + Lefty
>I have the Beall Tilt Box and a JET southpaw. The Tilt Box has been terrific in setting not only my table saw, but also the SCMS, and the jointer fence in both directions.
If you want dead-nuts consistency in making the same cut angle regardless of which machine you're on, I think this thing is indispensable. All you do is "0" it to the reference surface, sick it to the tilting surface (blade or fence), and match the angle desired in the meter. If I rip a 32� chamfer on the saw, I can joint the exact same 32� on another piece on the jointer and the two cuts will match perfectly because they were set with the same tool to the same tolerance.
Ralph Turney
>Just how accurate are these things??? Is there a full degree of tolerance play? Yes, yes, I know it's wood, but when making a box, setting up the jointer or something where the accumulated out of tolerance measurement can add up to a lot, I think it need to be very accurate.
Ralph
>Accuracy is supposed to be +/- 0.1 degree.
Lee
.1 degree makes can be a big deal.
Ed Snow
>For the same money you can buy a decent import vernier or dial universal bevel protractor and get approximately 10 times more accuracy. This is critical when setting up for compound mitres. The benefit is the tool can very accurately set up both.
Fred Davis
>Well George ,
I don't know what your during wrong , but the Wixey angle gauge reads direct just fine on my PM 66 left tilt TS
Maybe you aren't zeroing it before you stick it on the blade>
FredD
Dan Mitchell
>George - After my recent thread on them, I ended up getting the Beall, which is supposed to arrive tomorrow. Even managed to snag mine at Hartvilletool.com for 8 bucks off and no shipping (or tax, in my case), which sale I'm sad to report is no longer in effect.
As a bit of a "precision nut", I'm anticipating getting quite a lot of use from the tool.
Regarding the Wixey's left-tilt-ability, it does appear to be possible, if this pic from the Hartville site is any indication:
Dan
George (Oxford, NC)
>Col -
I didn't understand the problem so I went out to the shop and checked my Wixey on my LT PM64A. I still don't understand the problem. I measured the angle at 90�, tilted the blade and put the Wixey on the right side of the blade (the up side) and got a direct reading. Just to double check, I took and set a beval gauge to some unmeasured � and measured it tilted to the right and tilted to the left and got the same direct reading both sides. The only thing that changed was the little arrows on the left side of the display that point up if the left side of the Wixey is up and down if the left side of the Wixey is down.
George
Jim DeLaney, Austintown, Ohio
>George,
I think these guys want the Wixey to count from 0 0176 up to 45�. instead of counting from 90� DOWN to 45�.
Stands to reason that if you zero it on a horizontal surface, then magnet mount it to a vertical one it'll read 90�, doesn't it?
Now, the Beall tilt box is a different story: It has the magnets on the side, so if you zero it on the table, then adhere the SIDE of it to a vertical blade, it'll still read 0�. Then, as you tilt the blade, the Beall will count UP to 45�
Jim D.
ToMAYtoes / ToMAHtoes
>Any way youz pour it, it's still sauce. If yanowudimeen.
tp
>Hi all,
I'll give you an example of whats happening when I use the Wixey and what George D is claiming.
I set the Wixey device on the TS table top(Right side of blade on cast iron table top, not zero clearance throat plate), then I set it to zero, then I put it on the right side of my blade and it reads 90.
Now at this point I would like to tilt my blade to 11.3, so as I start to tilt the blade (I have a left tilt) it starts to go down from 90, (ie, 89.9,88.8,88.7 and so on). So even though my starting point is at 90 degree, it's not like starting at 0 and will count up 1-45 as I tilt the blade.
So I have to subtract 11.3 from 90 which gives me 78.7. That's fine, I can figure this out, but who the heck wants to calculate every time, after all this thing is a digital device and we are trying to make things efficiant, yet accurate.
It would make sense for the devise to start from 0 and go up as I tilt the blade so I can stop when I get to 11.3.
For any of you who claim there are no problems at 90 and 45, well you are correct,thats the easy numbers. Zero it out, slap it on at 45 or 90 and all is well. Try and find 11.3
Hope this helps explain a little more.
Thanks
Tim
OMYGOD!!!! A Believer!!!
>Right Tim, and well said.
Folks, it was Tim's machine I borrowed in the first place. All I want is something which will tell me what angle my blade is set at without having to subtract from 90 degrees, mount the device on the underside of the blade where I can't see it too well, and not have to run(that'll be the day) around and view the works from the back side of the saw to get a direct reading. OTOH, I could forget all about it and keep using a square to tune the blade to the saw, and blind trust in the miter scale on the saw. That seemed to work well for nearly 70 years.
George
Re: OMYGOD!!!! A Believer!!!
Eric Murphy
>George, I ordered the Beall Tilt Box for my father's day present. I will post and let you know hos it works out on my left tilt in a few days when I get it.
>It'll work just fine! I have both the Wixey and the Beall (Beall was a gift).
I prefer the Beall for the tablesaw - any tablesaw, it'll work the same on either left or right tilt.
