Triton Router
Don Evans
>I've had a problem with removing bits since I purchased my Triton 2 1/4 HP Triton router. The bits, 1/2" shank, would stick in and could only be removed by a few good licks with a hammer.
Today I decided would be the day I figured out what was wrong as the book called the collet a "self ejecting" collet.
Anyway, I called the repair center in New York state and learned that my unit didn't have the collet inserted correctly in the nut. After learning this and inserting the collet into the nut as it should be with a block of wood and hammer, viola the collet now works great and removes the bit when it is loosened.
I only mention this here because I remember many months ago this being discussed on the forum and no one seemed to know the answer at that time, this was many many months ago.
If there is anyone else out there with this problem and doesn't know the answer yet, let me know and I'll detail more so you can stop being frustrated as I was.
I don't use my router very often so that's why this went on so long.
I also learned that you should never tighten down the nut on the router with NO bit inserted. This will cause the nut to come loose from the collet and will no longer be self ejecting until repaired again. Also when this model router was new, they were being shipped with the 1/2" collet tightened down on the router and they no longer come that way so you may have never experience this problem, I happen to have purchased one of the first.
Don
