Old stored lumber cleanup
Dick Coers
>I spent several hours today helping an old friend's wife inventory a BUNCH of lumber that her husband stored in a barn. He's not gone yet, but alzheimers has really taken it's toll. My question is about cleaning up the wood. All the top boards are covered with inches of possum feces, pigeon feces, mouse droppings, 1/4" of dust, etc....... My first thought is to pressure wash off this bio hazard, but wonder if making it all wet might even be worse. It was all solar kiln dried. Any ideas? Anyone near Central IL interested in a 2,000+ bd ft of mixed hardwood? The range is from 16/4 walnut to 4/4 catalpa. It's a huge inventory.
Re: Old stored lumber cleanup
terry quiram
>Dick
When I got a truck load of old Mahogany from an iron foundry it was covered with some of the foulest smelling dust and sand. I pressure washed it and left it outside for the day to dry. It was the only way I was going to be able to use it. I have had no ill effects.
Terry
I've seen a lot of lumber like this.......
Bill Tindall, E.TN
>pressure washing sounds like a good idea. The water will not penetrate significantly so the lumber will dry quickly on a sunny day.
It will not be an easy task to sell this lumber. I have looked at many stacks of lumber in barns and never bought one of them. The lumber is usually log run which means there are all grades in a stack. The lumber is usually sawed by a small mill which can mean it is not sawed accurately. It will be dirty and unattractive. It may have suffered a bug invasion.
If someone is young and the price is right, this lumber could give someone an attractive opportunity for a life time supply of lumber. But the owner needs to appreciate it is probably not worth much.
Dan Clermont in Burnaby
>Pressure washing would be the best. It is always good to also use a wire brush to clean up the wood before using your power tools to get any concrete, stones or what have you off the surface.
Dan Clermont
I would start with a good shop vacuuming.
Keith Newton, LR, Arkansas------WebKitFormBoundary
>Wetting the outside of dry lumber runs the risk of causing internal checks due to the outside expanding.
