Grandfather clock "Sound Board"
Wayne Carson
>I built a Grandfather clock a few years ago and made a soundboard out of the same material as the clock "Red Oak". I have been reading that "Sitka Spruce" is a better material to use will it make the sound louder (which I want) or will it make a difference at all, The red oak kind of dulls the sound.
Re: Grandfather clock "Sound Board"
Pat Riley
>The tops of most acoustic guitars are typically some type of spruce. Old Martins used red spruce. I have built two small harps. I made the sound boards for them out of sitka spruce. It is surprising how much sound they can generate, but I have nothing else to compare it to. From what I have read, it could have a significant improvement, but only if built properly
The one thing you need to make sure of is that the spruce is quarter sawn (as vertical of grain as you can find), and that it is tight grained. Folk harp builders usually suggest at least 12 - 18 rings per inch. Mine were about 8 rings per inch and still work great.
Alternative MATERIAL?????
Source for Sitka Spruce Quarter sawn
Wayne Carson
>Source for quarter sawn Sitka Spruce about 2 bf
Pete in Holland, MI
>Regardless of what the wood is made of, the sound board needs to be a thin piece of wood, and the larger the better. This sound board will be "excited" by the vibrations in the tone bar assembly. The larger & thinner the board, the easier it will be to vibrate, thus a better sound amplifier. The more it can vibrate, the louder noise it will produce.
Good luck !
How thin ???
Wayne Carson
Re: Source for Sitka Spruce Quarter sawn *LINK*
Kneale Brownson Dreaming of the Snow in N. MI
>You can Google Sitka Spruce or try
Aircraft Spruce
Re: How thin ???
Pete in Holland, MI
>If the back of the clock is made of 1/4" plywood, that otta be enough. If the tone bars are mounted on it, but close to any strengthening ribs/plates attach to the panel, the vibrations will be deadened.
