More shellac questions
Barry Rubenstein
>Has anyone used a scraper to remove fully cured shellac high spots ?
Barry Rubenstein
It takes a really thin scraper.
Ed Snow
>Mine is maybe all of 1/32", works better on varnishes though. No bur and not off the file you have to take it to your stones. You are better off just taking a white scotch brite or 4/0 steel wool to it.
If I might take a guess and you are wiping your shellac on you might need some lube for your applicator and to thin out your cut this will help even out your shellac. Recently, I have been using camelia oil to lube my shellac applicator (tampon?).
Re: More shellac questions
Ed Mulligan, Cape Cod
>I agree with Ed. Use your thinnest scraper. The shellac doesn't have to be fully cured, and this is the beauty of the scraper. Where sandpaper would quickly clog on newly dry shellac, the scraper will cut with ease. It gives a flatter surface than scotch-brite or steel wool pads IME. After you've scraped, continue with pads, sandpaper etc to the desired sheen.
Ed
DizD
>A single edge razor blade is the best tool you'll find. Use just like a scraper.
Rod Cole
>Yep, a single edged razor blade works like a charm, no need to sharpen or turn a burr. A utility knife blade works fine too and may fit your hands a little better.
