ADVERTISE HERE - FREE TRIAL
Help w/wax !
Help w/wax !
Help w/wax !
Barry Rubenstein
>I put 5 coats of shellac on a finished box (figured maple) and got some unevenness in the shellac. I used 1500 grit paper with water to make a slurry, and brought the high spots down. I then used a wax thinking it would bring back a shine but it didn't work.
What do I use to remove the wax but not the shellac (guess I'll apply more shellac coats when/if I get the wax off)
Re: Help w/wax !
Re: Help w/wax !
Rob Stokes in North Vancouver
>Mineral spirits will remove the wax and won't harm the shellac. But before you do that, try "wet sanding" the shellac using 1500 then 2000 grit and using more wax wax as a lubricant (the "new" wax will reconstitute the old wax). You may have to add a drop (DROP) of mineral spirits to the slurry reduce viscosity
Rob
Re: Help w/wax !
Re: Help w/wax !
Barry Rubenstein
>I have paint thinner. Will that do the same as mineral spirits, or cause more problems ?
Re: Help w/wax !
Re: Help w/wax !
Howard Acheson
>Paint thinner will work fine. Check the label on your paint thinner. It will say that it is almost all mineral spirits.
Re: Help w/wax !
Re: Help w/wax !
Thomas S Stockton
>Barry,
I don't have experiance with shellac but when trying to knock down high spots with other finishes 1500 grit is way too fine and it will just kinda ride over the high spots and make everything very smooth but not always flat. I would get the wax off and then sand it with either 400 or 600 grit using a sanding block if it is a flat surface and then go on up through the grits. You might find that you don't need to add another coat after all. When sanding with the 400 or 600 you won't need to sand much just enough to make it flat and even.
I usually do a real good sanding with 320 grit before I apply my last coat making sure that the finish is nice and flat and rub the final coat out with 4/0 steel wool and wax
Tom
Re: Help w/wax !
Re: Help w/wax !
Barry Rubenstein
>I'm kinda apprehensive about all that sandpaper Tom. I used paint thinner and removed all the wax, then applied more shellac (using one of those small applicators usually used on housepaint; looks like very high & coarse velvet). I still have some bumpy spots. I might prep a really thin scraper and try that. What's the worse that can happen ? It's only shellac; easy on, easy off,and easy on again.
Re: Help w/wax !
Re: Help w/wax !
>Yup - he's right. Paint thinner is "dirty" mineral spirits - that's to say it's mineral spirits with other stuff added.
Rob
Re: Help w/wax !
I'm no expert but from what I have read wax is a
on Henthorn
>substance that will stick to most anything but itself. Once a coat of wax is thoroughly applied and thoroughly rubbed out, more coats do not accomplish anything. Just my observation from reading about wax.
Re: Help w/wax !
Re: Shellac
Glenn Madsen, SF Bay Area
>So how thick is the shellac cut?
On final coats that need to be really clean, I'm using a thin, 1 lb cut (or so). There should be no runs, drips or errors. (Sorry, Krylon, for stealing that.)
And I pad mine on.
